OBD II Scanner question????
Old Oct 18, 2004 | 12:50 PM
maxlauj95's Avatar
Does the OBD II Scanner be able to scan 95 Max? My cousin have one and we try to scan for code on a 95 max but couldn't find the plug-in harness for the OBD II scanner.....If 95 max do compatible then know where i can find the plug-in wire????
Old Oct 18, 2004 | 12:55 PM
Zach95SE's Avatar
Well odds are you are looking under the drivers side of the dash but its on the passenger side under the dash to the right of the center console. I'm pretty sure I mean I have done it a couple times.
Old Oct 18, 2004 | 01:02 PM
MDeezy's Avatar
I have heard that the 95 max can be scanned with an OBD-II tool, it was equiped an abel to be scanned with the II rather than the OBD-I, forgot where I read it from.
Old Oct 18, 2004 | 01:16 PM
Tyrexx's Avatar
I think the plug is next to your ECU comming out the right side.
(on a 95)
Old Oct 18, 2004 | 02:54 PM
maximum810's Avatar
On my 99 max, the OBDII port is right by the fuse box on the left side of your steering wheel if you're looking at it. I heard that most 95 maximas are OBDII...so...
Old Oct 18, 2004 | 03:01 PM
s0ber's Avatar
Uhm.. The OBD-II is on the passenger side right next to the ECU... for 95's...
Old Oct 18, 2004 | 03:16 PM
Tyrexx's Avatar
YUP
Old Oct 18, 2004 | 03:43 PM
Turk's Avatar
All 1995 Maximas a OBD-II, everyone single one of them.
Old Oct 18, 2004 | 03:57 PM
Terran's Avatar
Tman, was that a question? If so then yes. Although I'm not sure they are fully OBD-II.
Old Oct 19, 2004 | 12:07 AM
Turk's Avatar
It's not a question. I was pointing it out. Every single 4th gen (95-99) are OBD-II
Old Oct 19, 2004 | 06:42 AM
maxlauj95's Avatar
Thanks for all the point out where it located...much appreciation....I did located after all...Thanks once again to all the org members who help.
maxlauj95
Old Oct 19, 2004 | 05:52 PM
timk22's Avatar
the left side connector, near the fuse box, is for the tranny............
Old Oct 19, 2004 | 06:50 PM
A32Matt's Avatar
how come on the knee bolster, there is a label on my '95 that says it's OBD-I?
Old Oct 19, 2004 | 07:32 PM
timk22's Avatar
Actually, the connector by the fuse box is used by the Nissan CONSULT tool for both the ECM and the Tranny.
The connector on the front, right side of the console near the ECM is for a Generic Scan Tool (GST).
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
