i have a 100k on my tranny should i do the Drop resistor mod?
Old Oct 20, 2004 | 03:25 AM
2 Da Max's Avatar
i want a little extra power to my car without spendin money is it ok if i do the dr mod without fawkin up my tranny? this is my 2nd tranny its a 99 from an i30 and i already have a haydene ultra cool tranny cooler thanks
Old Oct 20, 2004 | 06:41 AM
NmexMAX's Avatar
dot dot dot ...
This wont add power.
And yes it would be okay, read the stickies because you want to install either a WOT swtich or manual switch, but do not want to use it when driving normally, and look for Jimes write-up in the nitrous section.
It helps your tranny live longer actually.
Old Oct 20, 2004 | 07:23 AM
TonyGotSkilz's Avatar
I've tested this mod at the track and i can vouch, its useless. I ran 6 times 3 with and 3 without drop mod and all three runs without were faster (and this was on the same night, one time off one time on, then repeated so the results should be unbais. As far as making your tranny last longer i have no idea, i can tell you that it shifts WAY too aggressively though for everyday driving it hits in so hard that it feels like your tranny is going to explode every shift. I would definitely not recommend it especially since theres no real benefit.
Old Oct 20, 2004 | 07:31 AM
Jime's Avatar
It probably won't make you go faster especially N/A. I use it to save the transmission from taking so long to shift and it does work by reducing the wear time on the clutches so there is a REAL benefit.
Its not to be used except at WOT as per the FAQ's, its not for everyday driving.
Where it really shines is when you are really putting down power ie 300 HP+. The transmission takes forever to shift under that much power and the DR mod reduces this time considerably and does made a dramatic difference in 1/4 mile times under those conditions.
Old Oct 20, 2004 | 07:36 AM
PAREDLINE's Avatar
make sure you change the fluid and filter too. Use high quality fluid and a bottle of lubeguard. I love lubeguard. My dad's olds has 150,000 on the tranny and it still shifts like new.
I just do tranny flushes every year.
Old Oct 20, 2004 | 09:21 AM
2 Da Max's Avatar
dam i just have an intake, so i guess it wont make a difference then. i am going to use a manual switch
Old Oct 20, 2004 | 09:28 AM
MaximaSE96's Avatar
Maxima Owner
manual switch here i come....i go WOT on the street alot too but i dont think i need if for the street
Old Oct 20, 2004 | 09:34 AM
Cheezwiz's Avatar
Not to the flywheel, but to the wheels... yes.
Old Oct 20, 2004 | 09:36 AM
Cheezwiz's Avatar
When shifting, that is.
Old Oct 20, 2004 | 09:41 AM
NmexMAX's Avatar
dot dot dot ...
Won't add power anytime during the 0rpm-fuelcut.
Only gets AVAILABLE power to the ground quicker.
Old Oct 20, 2004 | 10:57 AM
tedo007's Avatar
faster than you think
fast shifting thas what it is
Old Oct 20, 2004 | 11:19 AM
2 Da Max's Avatar
alrite guys so im going to do this today and i hope i dont **** up my tranny
Old Oct 20, 2004 | 12:16 PM
NmexMAX's Avatar
dot dot dot ...
As we've stated before,
Points of interest:
Make sure its connected to a switch, you want it to shift with the d/r under WOT ONLY never under normal driving, try it for yourself, and see what we mean if you must.
Old Oct 20, 2004 | 12:25 PM
2 Da Max's Avatar
**** these codes came up, Front Left Heated O2 sensor Automatic Transmission, Control Unit Signal to ECU,and Line Pressure Solenoid Valve (Automatic Transmission) the control signal to ecu came on since i put the new tranny in. but dam that **** shifts qwikkk, i nearly lost control of the car. btw uhm that microwave switch, that will turn on the dr if i get it for WOT?
Old Oct 20, 2004 | 12:27 PM
NmexMAX's Avatar
dot dot dot ...
Read the stickies. . .
or '
http://forums.maxima.org/showthread.php?t=285482
Old Oct 20, 2004 | 12:45 PM
2 Da Max's Avatar
http://www.radioshack.com/category.a...5%5F005&Page=1
which one is it? i still dont understand how the WOT switch works, does it sense when the throttle body is open or sumiting? i read the sticky but i dont understand it works i duno maybe ill just do a manual switch. help
Old Oct 20, 2004 | 12:52 PM
NmexMAX's Avatar
dot dot dot ...
Go to your local Radio Shack and see what they have, because I wasn't able to find one online, and the shipping would be more than the part.
I got one that has N/C and N/O you need N/C for sure.
Old Oct 20, 2004 | 12:55 PM
amulla01's Avatar
Is This Mod Only For The Manual?
Old Oct 20, 2004 | 01:09 PM
NmexMAX's Avatar
dot dot dot ...
Old Oct 20, 2004 | 01:15 PM
DeepBlueSE's Avatar
read the "Stickies" up top mang. this is only for Auto's. Yes, I've done it to my max too. I have over 100k miles. I'm using a manual switch, under WOT the shifts are a lot faster but harder. Don't do it for normal driving cuz , yes, it feels like my tranny will explode during the 1-2 shift.
Might want to invest in a tranny cooler too. Read the FAQ's about that too.
Old Oct 20, 2004 | 02:59 PM
2 Da Max's Avatar
i hooked up a manual switch today but im afraid the wiring will get messed up so i might get the switch. I still dont understand how that WOT switch works could some explain, sorry if its a retorquel ques but im tired and drunk
Old Oct 20, 2004 | 03:01 PM
NmexMAX's Avatar
dot dot dot ...
If you're drunk, you're incoherent, and explaining would be useless.
Old Oct 20, 2004 | 03:03 PM
2 Da Max's Avatar
lol not drunk like that, i mean im SLOW okay im not the smartest dude in the world. neways could u explain how that WOT switch works nmexmax, i mean you helped me out so far and i appreciat that so just explain to me if u dont mind how that wot switch works
Old Oct 20, 2004 | 04:46 PM
Tyrexx's Avatar
a WOT switch too hard to position, (im lazy) when i do DR its going to be a regular switch, just know when to use it.
Old Oct 20, 2004 | 05:02 PM
2 Da Max's Avatar
i was testing out the switch to see which is on and off, and when u hit the gas from a stop when its on it feelings like doing a nuetral drop. [ i scared]
Old Oct 20, 2004 | 05:09 PM
jm5464's Avatar
What I understand from reading the Stickies and how tos is: By disconecting the drop resistor, using a switch, it causes the car to shift as hard as possible, so, What if you were to put in a resistor with more resistance than the stock one, rather than entirely disconecting it. Would this cause the car shift harder without being to hard for everyday driving (depending on the amout of resistance) or would it kill the computer?
Old Oct 20, 2004 | 05:29 PM
2 Da Max's Avatar
hmm more resistance huh. i guess nobody wants to go through the hassle of doing it, but it will still be hard on the tranny, and not suitable for everyday driving. the thing is with the switch if i am going to race some one, i know im going to forget to turn it off lol
Old Oct 20, 2004 | 05:36 PM
sunten1
whoa when you guys are saying that you shouldn't drive with it on every day....does that mean the its bad for the tranny after long usage or does it mean its just not comfortable driveing with the DR mod???
jm5464's Avatar
It would acctually be easy. Just get a resistor with slightly higher resistance that can handle the same amout of current and put it in the place of the stock resistor. I just don't want to try it b/c I don't know if it will damage my computer. Does anyone know or have the ***** to try it?
If the tranny were to shift slightly harder it would actually make the clutches in it last longer (less slipping). The clutches are what tend to go first. When I had a shop rebuild my previos cars transmition I had him make it shift slightly harder and he said it wouldn't damage it or significantly decreace the life of it.
Old Oct 20, 2004 | 05:59 PM
2 Da Max's Avatar
dude that **** will mess up your tranny for everday driving man
Old Oct 20, 2004 | 06:15 PM
Jime's Avatar
Resistances both higher and lower have been tried both with fixed and a variable resistor. The nature of the circuit does not lend itself to changing the level of pressure from anything from normal to maximum pressure. Good idea though I thought it would work too.
I spent a lot of time trying to accomplish this as well but feel free to try again, you won't hurt anything by just varying the resistance.
Old Oct 20, 2004 | 06:18 PM
jm5464's Avatar
Thanks, might give it a try if I have some fee time.
Old Oct 20, 2004 | 06:40 PM
NCSU_MAX's Avatar
Maximoneypit
PM Mad_Max_SE - i know hes been daily driving with the drop resistor mod for prob around a year. ive ridden w/ him alot and it does shift pretty hard but i dont think hes had any problems yet.
Old Oct 21, 2004 | 05:11 AM
At one point i used it for every day driving for like a month or so and i had nearly 150K miles on my tranny when i did it, and my tranny was fine, its my engine that eventually blew up my tranny had 180k on when i blew up my second engine and parted out my max That was the cars original tranny and even with those miles it worked just fine, even after drop mod. I don't know why everyone says the auto trannys are weak, with nearly stock HP to it they can last forever. And keep in mind me and my car did at least 100mph every time i ever got on the highway in it, I wasn't gentle with her in any way shape or form. BUT as far as day to day driving the drop mod is terrible, nobody will want to ride with you because they'll think your cars about give out and they'll be pushing.
Old Oct 21, 2004 | 09:25 AM
2 Da Max's Avatar
o ok thanks i was scared about the tranny messing up on me. i though auto cars blew trannys and stick cars blew motors. im just a little worried because last year i blew my tranny badly. the tq was all scratched and had dig cuts in it. everything else in the tranny was fried. i never did nuetral drops, i just used to do burnouts on the ice or wet road lol i knw that was when i was young and stupid. but now i am a little more careful
spencerwh1
Jun 30, 2016 05:44 AM
Turbonut
46
Oct 21, 2015 08:28 PM
bryants95max
Oct 2, 2015 12:52 PM
ballerchris510
Sep 23, 2015 08:46 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
