Short Throw Shifter ?
Old Oct 22, 2004 | 12:26 PM
Umass021's Avatar
I have a cosmo short throw shifter in my car. I have had it in for about 6 months now. Recently it felt loose when it was in gear so I tighten the bolt under the car, the bolt that goes thru the bottom of the shifter. Now my shifter is very tight to move and has trouble getting in gear. It also makes a sqweaky noise when I shift. Should I loosen it back up a little or is there another problem with it?
Old Oct 22, 2004 | 12:43 PM
Flava_24/7's Avatar
Boosted Panda
You tightened it too much. Get back underneath and loosen it up, then tighten a little at a time, get in the car and go through the gears. Once you have a desired feel. Stop tightening.
Old Oct 22, 2004 | 01:29 PM
GodFather's Avatar
Made in Taiwan
it's too tight, i did the same thing, then i went down again to re tighten it to my desired level. after that, i bought another nut and screw that one in to make sure it wouldn't get loose again.
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 31, 2015 02:04 AM
atriuum
Sep 28, 2015 01:19 PM
