Mevi??
Old Oct 22, 2004 | 01:43 PM
JetBlackMax83's Avatar
Mevi??
ok idk this my be a stupid question but what is the point of a mevi does it increase hp and where can you buy one i read the write up on how to install it just wondering..?
Old Oct 22, 2004 | 01:58 PM
Dubbya's Avatar
VK56 Inside
My understanding of the MEVI in a nut shell is that it shines throu on highway type speeds and does nothing if not subtract from low end. You can buy them from Courtesy Nissan in Dallas. Atleast you could.
Old Oct 22, 2004 | 01:59 PM
wildmaxi's Avatar
hmmmm....huh????
Old Oct 22, 2004 | 02:03 PM
Dubbya's Avatar
VK56 Inside
Quote:
hmmmm....huh????
go read the stickies then. and you can buy it from Courtesy Nissan last time i checked.
Old Oct 22, 2004 | 02:05 PM
DAVE Sz's Avatar
Hooooooonda.....
courtesy hasn't sold them in months.
Old Oct 22, 2004 | 03:37 PM
tedo007's Avatar
faster than you think
rather do the real VI conversion from 2k
Old Oct 22, 2004 | 03:39 PM
i30ds's Avatar
Armed and Dangerous
All it does is continue to create peak hp past 5200 (I think) rmp to redline, where the USDM manifold normally drops off at around 5200. The best advantage is felt with an ECU mod, and increased redline. I does take a lot from the low end though.
Where would you get one then? I doubt the guy mentioned in the stickies still sells them.
Old Oct 22, 2004 | 07:26 PM
Guinader's Avatar
besides wildmaxi, (and me now) everyone on this thread has joinned the .org on the year of 2004 (except DAVE Sz which i belive knows more)
so, funny what reading trogh the pages of the .org can answer you questions.... I 'm very icoherent right now, so I will stop...
Old Oct 22, 2004 | 07:36 PM
Magikone69's Avatar
the mevi is a dual runner intake manifold with long and short runners, at a specific rpm the runners switch to enhance breathing at the higher rpms to help get more power. its true the ecu helps get more power in addition to the MEVI since it gives you an extended redline. im sure the adjustment on the timing and the fuel map also helps. MEVI stands for middle eastern variable intake. there is a variable manifold off the vq30dek engine 2000-2001 maxima. The upsides are extended power after 5200 rpms but there are downfalls like suffered low end power and risks like screws coming loose off the butterfly valves and getting sucked into the engine. as far as buying one, im not really sure anymore. courtesy i heard doesnt have em anymore.
Old Oct 22, 2004 | 08:32 PM
RyanTaylorClark's Avatar
Thorough description (including pics) of a MEVI from the best Maxima site out there (in my opinion). Includes dyno's and install instructions.:
http://www.vqpower.com/v2/article62.html
Group deal that started a few months ago on MEVI's. Includes a site to order them from on page 2.:
http://forums.maxima.org/showthread....6&page=1&pp=30
One of the many good MEVI links here on the .org that discusses frequently asked questions regarding the MEVI and even has links to just about every MEVI discusssion on the .org (thanks to JeffesonM).:
http://forums.maxima.org/showthread.php?t=217001
Hope this helps.
Old Oct 22, 2004 | 10:53 PM
I30tMikeD's Avatar
An MEVI does not have two seperate runners and either does the 2K-2k1 manifold. They both use resonance chambers for the high rpm change over.
Old Oct 22, 2004 | 10:58 PM
DAVE Sz's Avatar
Hooooooonda.....
Thanks for correcting them Mike before I did. Both the mevi and the 2k+VI are not dual runner designs, they're more of a single runner with additional space for top end power. If I were to get either I think I'd fo for the 2K VI, there's some custom work but I'm up for it. I'd of course need the TB/IACV adapter or get rid of it completely like BSwift or whatever it is.
Old Oct 23, 2004 | 07:54 PM
Magikone69's Avatar
thanxs for correcting me, i guess i got a lil confused about the dual runner thing. good lookin out.
Old Oct 23, 2004 | 08:16 PM
michaelnyden's Avatar
I have never known anyone who has had the butterfly screws fall off and into the engine....neither have I ever read or seen a thread where this actually happened to someone....but rather people speak of it as being possible....
Old Oct 23, 2004 | 08:20 PM
Terran's Avatar
It happened to somebody a little while ago (probably within the last month or two).
Old Oct 23, 2004 | 08:24 PM
I would imagine that would cause a huge amount of damage!
I will have to check mine soon then! any suggestions besides that red locktite stuff to use on them?
Old Oct 23, 2004 | 08:34 PM
Terran's Avatar
I believe people have had them welded on. Maybe you could even solder them...Don't really know.
Old Oct 23, 2004 | 10:14 PM
Magikone69's Avatar
meccanoble was one of them if i remember correctly, it just happened not to long ago.
Old Oct 24, 2004 | 12:07 AM
Supermax95's Avatar
anyone know of a writeup for the vi from the dek??
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Nov 29, 2017 08:52 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
