Chnaged ATF after 89k but problems arise
Old Oct 24, 2004 | 12:45 AM
amulla01's Avatar
Hey all, today I got around changing my axle shaft and that requires draining the pan, so I drain it and add about 5 quarts of nissan o matic atf after 89k mileage of not changing any atf before... all seemed smooth and no leaks, I drove around at first and shifter was very smooth. Then I drove another 50 miles. Parked, came inside and now the shifter when I press park, reverse, or whatever, the shifter is very STICKY, it feels like it s barely moving... I check the fluid level and it seemed very low and I guess it was leaking during the trip... I added some mobil 1 atf at local station (1 quort)... still now the stupid shifter seems horrible... what is axactly causing this? Before I changed fluid, I went to nissan dealer and they charged me 30$ for 5 quorts, and I asked him to give me new drain plug, but he told me I dont need it and I can reuse the plug(looking like im a moron). I also asked him if I could clean drop the pan and clean it and clean the filter... again looking at me like i am a moron, he tells me that technics dont do that and it is highly not recommended to clean the filter or drop the pan... he almost laughed at the idea... so now cause I took his advice and didnt get a new drain plug, I dont know what my fluid level should be like (i matched before the leak perfectly)... I think i overfilled it with nissan atf and mobil atf... anyone know the level it should be on... my dipstick is freaken weird i swear... I got hot on one side without any indication and cold on the other side with no line indication... i know it has to be between hot and cold
anyone could tell me what's wrong with my shifter?
Old Oct 24, 2004 | 12:47 AM
amulla01's Avatar
i saved 5 quorts of old atf, should i put it back in there?
Old Oct 24, 2004 | 06:23 AM
njmodi's Avatar
Do I get a tax break?
Are you sure its not leaking from the axle shaft seal?
Old Oct 24, 2004 | 07:01 AM
crazy97's Avatar
Did you mix the nissan atf and mobil atf? This should be ok but I have had problems with mixing atf fluids on my other car -Jeep Grand P.O.S. Also when I over fill it, it slams into gears when coasting to a stop instead of softly downshifting. Using only the nissan atf would be a safe bet.
Make sure your car has been driven for at least 15 min (some freeway is best) before checking for the 'Hot' level.
Old Oct 24, 2004 | 08:14 AM
amulla01's Avatar
well the shaft is still the broken old one since I got past the axle but had no leverage for the 2 bolts that hold up the wheel(didnt have a breaker bar less than .5 inch)
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
