Airbag light reset
Airbag light reset
.. Hello all ,
I have a 1995 Max and everso often the airbag warning light will come one and stay blinking after start up. I had it reset at the deeler a few times but it has eaten a hole in meh pocket ..does any one know how to reset it withe out goin to the dealer.
directly from 4th Gen How-To
http://forums.maxima.org/showthread.php?t=254238
"How to reset SRS(air bag) light
Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine.
If the airbag warning lamp is still on (or still flashing), there is a fault in the Supplemental Restraint System which must be diagnosed and repaired. This is a job for your local friendly Nissan dealer."
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
