9007 conversion issue..need assistance
Old Oct 28, 2004 | 05:31 PM
mansurxk's Avatar
i upgraded to the nokya 9007 harness on one side to compare the difference from 9004. i used nokya 100/120 watt bulb, the low beam seems fine, but the high beam seems really dim, its dimmer than the 9004 bulb low beam. what could be the problem, im 90% sure i wired it correctly, but its dark out so i cant really check it out right now, ill probalby check it out when i get home from work tommorw.
Old Oct 28, 2004 | 06:21 PM
njmaxseltd's Avatar
Sounds like a wiring or ground issue.
Old Oct 28, 2004 | 06:35 PM
mansurxk's Avatar
i think theyre aimed too high, because i went outside just now and i looked in from a higher angle and it wsa blinding me, i guess i gotta point them down, and its probalby the beam pattern from a 9004 bulb im comparing it to.
Old Oct 29, 2004 | 02:42 PM
mansurxk's Avatar
nevermind...as usual Tom you were right, the ground wire was corroded just a bit, they werent aimed too high, just poorly wired. thank you
Old Oct 30, 2004 | 07:53 AM
RA030726's Avatar
I'm nutty for Nissans
damn too late to help ya. oh well happy modding
KabirUTA13
19
Oct 17, 2015 02:15 AM
Calabar
Oct 5, 2015 09:57 PM
kjlouis
Sep 14, 2015 11:22 AM
Hdnseek
Sep 9, 2015 05:55 AM
