Head Lights Lamp Problem
Hi guys,
I just noticed that my head lights lamps are malfunctioning. On the normal on setting, only the bulb on the right turns on. The left lamp doesn't.
When I switch it to high beam, both lamps light fine.
I don't see why it wouldn't light up on one setting, unless they use different relays for each lamp and each setting.
Has anyone encountered such a problem or may have suggestions as to what may be wrong? Any help on this is appreciated
Thanks in advance.
99 SE
Thanks in advance.
99 SE
As you found out - the bulb has two filaments - and the low beam filament has blown. Call around your favorite auto stores...or just replace both sides with whatever variety is available locally.
OMG i had one confusing morning when both low beams blew out at the same time. I was without lows and i thought i popped a fuse. stupid rice blue bulbs. never once have i seen 2 bulbs blow together.
I recommend the Sylvania Xtravisions for a great upgrade while retaining stock color. Yes i have 9007, and i would never go back to 9004.
PIAA is $$$$ but owners say its money well spent.
unfortunately i got sylvania 9004 silverstars. I may just pick up a 9007 pair soon when i feel like buying something again, in a month.
From the PIAA, to el cheapo sylvania, I do not see a justification for 50 bux more spent on PIAA.
I have one PIAA bulb that is good, but no good to me.
doobadoo
Aug 15, 2015 06:43 PM
MikesChevelle
Aug 6, 2015 11:36 AM
yat70458
Aug 3, 2015 01:16 PM
