Noise when turning at low speeds.....
Old Apr 15, 2001 | 06:44 PM
Mad Jap's Avatar
Well, it's been about a month since I put my H&Rs in.
Now the springs are making noise (I think that it's shifting on the rubber seat at the top of the struts) when I turn the wheel at low speeds like in a parking lot.
Does anyone else have this problem? What's the fix?
It's pretty damn annoying at times....
Old Apr 15, 2001 | 09:44 PM
dch95's Avatar
Strut Bearings?
Perhaps the strut bearings are going out. You could check by having a friend turn the wheel back and forth and listen at the top of the strut mount a see if that is where it is coming from.
Old Apr 16, 2001 | 03:53 AM
Mad Jap's Avatar
Re: Strut Bearings?
I forgot to mention that I replaced the strut mounts and the strut bearings at the same time.
I can actually see the spring moving across the rubber seat and making noise.
Perhaps some lubricant would do?
Old Apr 16, 2001 | 08:48 AM
dch95's Avatar
Re: Re: Strut Bearings?
It would seem to me that doing so would make it worse. That is a puzzling situation. Can,t think of a check/fix for that. Only thing coming to mind is whether or not the spring is seated in the rubber groove in the upper mount or if it is off a bit. The rubber mount should have an indentation where the spring starts.
alahjahwan09
18
Sep 21, 2015 09:12 PM
LtLeary
Sep 14, 2015 12:33 PM
trungg86
Sep 4, 2015 04:58 AM
