just did flush
Old Nov 6, 2004 | 10:55 AM
S103100F's Avatar
just did flush
96 maxima gle auto
120k miles did my first transmishin flush and wow car shifts like newer b4 i love it
Old Nov 7, 2004 | 05:07 PM
ThurzNite's Avatar
No leaks, no problems? Sweet! what kinda flush was it?
Jae
Old Nov 7, 2004 | 05:39 PM
MDeezy's Avatar
he said it was a transmission flush.
good to hear on a good flush, I know I need one, I can feel the grinding
Old Nov 8, 2004 | 08:40 AM
S103100F's Avatar
i think my even pulls harder now
Old Nov 8, 2004 | 08:42 AM
S103100F's Avatar
i ment my car
Old Nov 8, 2004 | 09:05 AM
gto400no1's Avatar
where did you go and how much it cost, i have to have that done too.
Old Nov 8, 2004 | 09:44 AM
S103100F's Avatar
my friend did it for me cost me $100
Old Nov 8, 2004 | 10:36 AM
BaiCheSE's Avatar
how hard is it to do a tranny flush? what chemicals do u use?
how much time does it take?
Old Nov 8, 2004 | 10:38 AM
maximaintheface's Avatar
do it urslef it took me 45 minetes you just take the plug out drain it take the whole tray out clean the magnets get a fileter form like tem or somwhere for 12 bucks and it comes witha new gasget and then u put it on and add the fluid and then check it after its just as easy as cahnging the oil but a little messier. for best results do it like not to long after u drove it last so the fluid is hot and will clean it better.
Old Nov 8, 2004 | 10:40 AM
theblackmax455's Avatar
U don't use "chemicals". It involves forcing fluid in the system through the tranny, to push out the old tranny fluid and replace it w/ new tranny fluid instead. I know for a fact that the Valvoline Instant Oil Change around me does a good job. I used to work there, and I did more than a few cars for my friends, and they all noticed differences when they were done. Some Valvolines have different equipment than others, as far as the flush machine goes, so it all depends though. they charge about $90 for one here (Ohio), including fluid and everything.
Old Nov 8, 2004 | 12:18 PM
philly96maxima's Avatar
I cut and paste the following
"Leave it in Park.
The fluid comes out of the bottom connector on the trans and returns on the upper one.
Read this first for info on how to do the flush, install cooler and some pictures. If you are contemplating a trans cooler, now would be a good time to install it. Some recommend dropping the pan, cleaning the strainer and magnets which is a good idea but even the dealer doesn't do this. Its not a job for the average enthusiast.
https://maxima.org/shoptalk/sub_...ler/index.shtml
https://maxima.org/forums/audio-electronics/149056-question-people-have-installed-lcd-bose-hu-locatinon.html
Before you start, go and buy 10 qts of your favorite auto trans fluid. (I recommend Mobil 1 Synthetic)
The whole procedure can be done in 30 mins or less but take your time and do it right.
1. Jack up either the front or drivers side of the car and put in jackstand.
2. Remove the drivers side engine undercover.
3. Remove drain plug from transmission and drain fluid into suitable container, this will be approximately 4 qts. Insert drain plug and pour the same amount of new fluid into the transmission. (Transmission should now be back to stock level)
4. Disconnect the fluid supply line at the bottom of radiator. Its the bottom line connected to the transmission. (Be very careful removing this line, its very easy to break the hose nipple on the radiator) Put the end of the hose into a clean, clear or white plastic 1 gal container.
5. While you are holding the hose get someone to start the car until the transmission pumps out approximately 2 qts (half the container). This should take 15-20 seconds, its not really fast so don't panic, I do it all myself but its easier if you have someone to start and stop the engine for you.
Note: If the trans fluid comes out of the bottom of the radiator vs the hose you are holding you have the wrong line. Put it back on and remove the other one.
6. Pour the same amount of new fluid back into the transmission that you pumped out.
7. Repeat steps 5 and 6 until fluid changes color. Since you already put 4 qts in initially and the trans holds 9 qts we are talking about approx 5 qts. I buy 10 qts and remove that much just to be sure I got it all. (The trans flushing places use much more and synthetic fluid is expensive).
8. If your fluid is in fairly good condition the color change will be very small and may not be noticable so stop at 10 qts.
9. Reinstall hose to radiator, replace engine cover, lower car and recheck trans fluid level to make sure you have the correct level. Maybe even go for a small drive and recheck to make sure, its difficult to read at times.
10. There you have it. What you have basically done is removed all the fluid from the pan and replaced it. The internal pump takes its suction from the pan and pumps to convertor and all internal trans part then to radiator for cooling. So you have completely replaced all fluid internal to the transmission without shocking your transmission into submission like the force flush machines do.
btw When the dealer does a transmission fluid change all they do is drain the pan and refill, which is right from the FSM.
Also some people do a few drain and refills to change their fluid but all you are really doing is mixing 4 qts of new fluid with 5 qts of old fluid and pumping it around, eventually you would get a complete change but I really don't like the idea of mixing old and new, a complete change is very easy and does it all the first time with very little waste."
sctludwig
Sep 1, 2022 01:32 PM
user 11122324
42
Jul 18, 2022 03:35 PM
rbuswell
Nov 17, 2016 04:54 AM
RWCreative
Sep 21, 2015 11:01 AM
Violator
Sep 9, 2015 10:14 AM
