Newb questions about lighting not found in FAQ's
I have read the FAQ's and could not come up with answers for these, so I'm sorry if these are posted somewhere else.
With that out of the way...
1) Is there a complete bulb chart available?
I know the HL are 9004, tails 1157, rear turns 1156 and reverse 1156, but what about the rest? Interior too please, dash, dome, door etc... I want to change them all to LED blue inside.
2) How the %$&% do the clear fronts come off on the 98-99???
I couldn't find it, but I really didn't have time to look around and didn't feel like scratching the $#!t out of my bumper, so please... how do you pop them out?
Thank you in advance. I hope you guys can help, and if some day I can return the favor, I'll be glad to
I know 2nd gen Integras and 3rd Gen Eclipses... I am still the VP for an all Eclipse club www.socal3g.com so if you have friends in Southern Cali that drive 3G eclipses, they are more than welcome to come join us
1) go to your local auto store, (ie: kragen, autozone) and look at the books they have. it lists most of the bulbs for your car. check out your owners manual too for reference.
2) if youre talking about the cornerlamps you gotta take out one screw on the top with a philips head. then you wedge a flathead in between the headlight ad cornerlamp and search for a ball-and-socket joint. insert flathead inbetween joint and twist. it should pop off. be careful tho because part of that joint is plastic and its common for people to snap the joint apart. the first times always a ***** but after you do it a couple times itll get easier. good luck.
To take out the front bumper lenses:
1. Tools: pannel popper or flat head screw driver and a philips head screw driver
2. place pannel popper or flat head in the gap between the two lenses, pop out the rearward (parking) lens by moving the tool handle tward the front of the car.
3. Once the other is removed use the philips to unscrew the inner (turn) lens
Slamrod
Apr 10, 2016 05:24 PM
max_speed97
Aug 26, 2015 07:46 PM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
