Knock sensor revisited
Old Nov 8, 2004 | 10:41 PM
Akumachan's Avatar
I never narc'd on nobody.
ok, i know that everything i need to know about knock sensors is in the stickies, but mine seems to be some odd form of exception. before i knew how to get the codes from the ECU i tested the resistance on it, and i got an open circuit, as in, its dead. but then tonight, i checked the codes and got only one, 0402, and thats cuz i disabled the speed limiter. so, ecu thinks it works, tests and the butt-dyno tell me it doesnt work. what do you guys think? is it worth it to buy a new one and throw it in there just cuz it feels like it doesnt work?
Old Nov 8, 2004 | 11:02 PM
JDM_Maximus
make sure that youre not getting two codes.. there will be a slight pause after the first one (if there is two).. if there isnt a second one, then just make sure that 1) your voltmeter/ohmeter is working properly 2)make sure that when you test the resistance on the KS that you have a good ground (like the negative batt terminal).. and make sure that you have a good connection to the pin in the connector (remember its the pin closest to the front of the car).. i just replaced mine today.. and mine was not picking up ANY reading before.. it was just shot! and i replaced it and can tell a major difference.. even right off (before the computer has a chance to calibrate itself).. hey also you could try just reseting your ecu and then take down the road (minimum of like 1-2 miles) and then check your codes again.. if it still doesnt show up and you think that it its bad then i would replace it.. but i dont know why it wouldnt show up even when youre testing it and its not showing a reading on the ohmeter.. if you do end up getting a new one i got mine at
http://www.maximumautoparts.com/NI_K...OVMTC=standard
i got it for 115 shipped and shipping only took like 3 days to get here.. either that or i think you can also get one on ebay.. at the time when i ordered they didnt have any on there.. good luck man..
Old Nov 9, 2004 | 01:11 AM
Akumachan's Avatar
thanks a bunch jdm, i guess ill test it with the ohmeter once more, try screwing around with the ecu, and hopefully not have to buy one
Old Nov 9, 2004 | 04:52 AM
99se5spd's Avatar
check the specs on your ohmmeter, it should be capable or reading at least 10meg ohms, if it doesnt than it will read open lead even if the ks is good
Old Nov 9, 2004 | 10:58 AM
Akumachan's Avatar
i had it set to 20m ohms, that should be more than sufficient i think
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
