help help help please!!!!!!!!!!!!!!
Old Nov 10, 2004 | 02:50 PM
maxs4life's Avatar
The car will not start 4 nothing. It cranks like its about to start but nothing. The more i crank the more the engine gets flooded.
I've changed all sensors, starters, spark plugs, battery, even the engine. The engine because it had alot of miles ,but that still did not fix the problem. Had a friend replace the ECU and the igintion 4 me, and nothing. Everything works in the car a\c radio windows everything, just that the car will not start. Going back alittle before when the car was working it would take sometimes 2 to 3 minutes to start, other times 10 to 15 cranks it seem to always to have this problem. I took it to 4 mechanic and nothing ,tow ,tow and, tow im tried anybody have any ideas.
junking the car is not possible.
this car is really nice. help please
Old Nov 10, 2004 | 03:04 PM
Terran's Avatar
What makes you say you're flooding the engine? Has anybody checked the fuel pressure? Unless you're incredibly unlucky and both engines were broken then I would think the fuel pump is the only thing you didn't replace that would cause this.
Old Nov 10, 2004 | 03:07 PM
NmexMAX's Avatar
dot dot dot ...
High mileage, what's high to you? Was it working before the engine swap? My max has a lot of mileage, check sig, and starts everyday nicely.
ANd Terran's correct, if you indeed have changed everything else, even the engine, it's time to look at fuel starvation.
Old Nov 10, 2004 | 03:14 PM
MDeezy's Avatar
fuel seems like your source, so all the other parts you replaced in hoping it would fix the problem without diagnosing them first?
I'm just thinking that a lot of money to get a new ECU, All sensors, battery, or sparks it might just be me but that seems like at least $1,000 in changing all those parts when I'm sure the previous ones worked just fine. I hope you can return some of those parts to get some of your money back, or maybeyour fortunate with money.
Anyway I dont want to take away from the need for an asnwer, I a dead puel pump or something fuel related seems like your problem, and if 4 mechanics didnt think of that at all or didnt test any fuel options, then thats kinda scary.
Old Nov 10, 2004 | 05:53 PM
f550maranello2's Avatar
thats right man check the fuel pump. and the ecu as well as the fuel pressure regulator, my old car had the same problem and it was the fuel pressure regulator
