Rear End Sagging.... ?
Old Nov 13, 2004 | 11:30 PM
Vic99SEL's Avatar
For some reason my rear end of my car saggs more than my front, I have a box that holds two 12" subs in the trunk, but nothing spectacular just a regular box, plus my car is not lowered. Answers anybody?
Old Nov 13, 2004 | 11:56 PM
BadKarma99-4spd's Avatar
push on the back corners of your car, if it bounces a lot you probably need new struts. when you push on the corners of your car it should stop bouncing almost immediatly.
your subs could be causing the sag though, maybe take them out and see?
good luck
Old Nov 14, 2004 | 12:19 AM
VIP Maxima
our max's sit lower in the back, thats normal
Old Nov 14, 2004 | 05:15 AM
njmaxseltd's Avatar
Two boxes + gravity = a lil lower
The front fenders are cut larger then the rears to allow the front wheels to clear the fender edges when they are turned fully and your front suspension is fully compressed. Thats how the car is designed.
If you measure from the frame rail to the ground at the jack locations I'm sure you'll find your car sits pretty level.
Old Nov 17, 2004 | 05:28 PM
Vic99SEL's Avatar
Yeah, I noticed other Maxima's have a little sagging in the rear. I guess that is normal. Thanks for the info.
Old Nov 17, 2004 | 05:41 PM
A Flood99's Avatar
get S.tech springs and you'll be sitting lower in the front than the rear......crazy @ss difference compared to stock
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
