remove the ashtray
Old Nov 15, 2004 | 04:00 PM
sunten1
remove the ashtray
ok i have been trying to do this for the last few days....and i can't seem to get this piece of **** out....i took out the caseing around the shifter and tryed pulling it out and got nothing....so i tried to take out the console(where the headunit is) and not luck there....
and yes i did unscrew the screws....
pics wouldn't hurt
Old Nov 15, 2004 | 04:18 PM
bullfrog's Avatar
i got it done with this guide. i also had some trouble removing the ashtray for a while and i thought i had taken out all the screws, but it turned out i had forgotten one. dunno if that helps at all, but good luck with it.
Dubbya's Avatar
VK56 Inside
There is one screw holding tha ashtray in. All you have to do is remove the bezel around the shifter and look for a screw on the drivers side of the ashtray. Remove that and you will have to wiggle it around a bit to make it come out. Hope this helps!
Dub
Old Nov 15, 2004 | 04:28 PM
Igobuk's Avatar
OPEN it. The ashtray won't come out unless it's OPEN. Seems crazy but try it and see.
Old Nov 15, 2004 | 04:33 PM
sunten1
ohhh man thanx for the quick resonponces!!!!...ill have ti work on it tomorrow
Old Nov 15, 2004 | 06:38 PM
l3ftonm3's Avatar
yah Ive been wondering how to do this also. I have a Rockford fosgate amp w/ the separate gain control and want to put it in the ash tray instead of underneath the dash. I saw someone on here w/ this setup and have been wanting to get it done.
Old Nov 15, 2004 | 08:25 PM
sterlingmaxima's Avatar
all you need to do is get your hand behind there and push that sucker out get your hand wedged behind the ashtray and push it is held in by clips your notgonna brake anything.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
