Polished Al Head (pics)
Old Nov 16, 2004 | 11:09 AM
Oblongshapes's Avatar
Hey, Ive started to Polish the head. I stopped at 320 grit wet sanded and then I steel wooled it. Someone told me that mothers metal polish works great on this...... anyone ever try it?
Pictures
Pictures dont do it proper justice...
Old Nov 16, 2004 | 11:13 AM
Jeff92se's Avatar
I'm needing a caw
Hate to break it to you but that's your valve cover. Try a small spot with some 3m rubbing compound. The follow up with the mothers or some other alum polish. I hope you aren't doing this by hand
Old Nov 16, 2004 | 11:22 AM
jdm71488's Avatar
now do the intake manifold...
Old Nov 16, 2004 | 11:27 AM
chenzarino's Avatar
Keep going with the sandpaper, make that b**ch mirror finish
Old Nov 16, 2004 | 11:34 AM
Broaner's Avatar
2060lbs and falling...
You'll be doing that forever. I gave up and painted it semi-gloss black. Yes, Mothers Mag Aluminum Polish will make that bling if you sand it enough. The IM is even more impossible.
Old Nov 16, 2004 | 11:39 AM
Intel's Avatar
If you want a mirror finish you have to work from about the 300 range up to almost 2000.. This will keep on making the scratches made by the sandpaper smaller and smaller. Then you want to come in with a polishing wheel and some agressive polishing compound and then work up to Mothers Polish.. hopefully then you will have a mirror finish. I am at about 1500 grit and should be able to finish that up this winter break and get it looking really good.
Old Nov 16, 2004 | 11:41 AM
jdm71488's Avatar
lol, you might as well be saying... well you start now, and finish by the time you sell the car... and hopefully then it'll be where you want it...
j/k... keep at it...
Old Nov 16, 2004 | 11:43 AM
Jeff92se's Avatar
I'm needing a caw
IMHO I think this is incorrect. Reason. When you go all the way up to 2000 grit then to some aggressive polishing stuff (ie.. rubbing compound) you are actually going back down to something less than 2000 grit. It's much easier to stop at maybe a 600 grit and use rubbing compound and a machine and work up. Or else you will be sanding for an eternity. I'm not saying your method won't work. It should work very well. Just very time consuming IMHO
Old Nov 16, 2004 | 11:58 AM
Nismo3112's Avatar
Custom User Title
Put some more elbow grease into it. And yes use Mothers, it will take a while, but it's worth it:
Old Nov 16, 2004 | 12:14 PM
jdm71488's Avatar
my gosh thats beautiful! it looks to be made out of cheap silver its so shiny! lol
Old Nov 16, 2004 | 12:19 PM
1MAX2NV's Avatar
You still have a long way to go. You need polishing compound like Tripoli and a buffing wheel. It takes alot of heat to remove material.
Old Nov 16, 2004 | 12:47 PM
97WhtSE's Avatar
Looks good.
Hey 1MAX2NV how did u get ur intake manifold so shiny?
Old Nov 16, 2004 | 01:25 PM
A Flood99's Avatar
what tool would you guys recommend when trying to polish it up like above?
is there anything in the stickies about all of this?
Old Nov 16, 2004 | 01:54 PM
s0ber's Avatar
seriously, someone needs to make a lil writeup or something lol for the noobs like me when it comes to sanding stuff down..
Old Nov 16, 2004 | 02:00 PM
Jeff92se's Avatar
I'm needing a caw
Some initial pics of my project
http://forums.maxima.org/showthread.php?t=275563
After. Not professional but not bad for diy and all the damned crevices
Old Nov 16, 2004 | 02:19 PM
1MAX2NV's Avatar
Professionally done. You can't pay me enough to do that by hand. Air tools and power tools are needed to get it that shiny.
Originally Posted by 97WhtSE
Looks good.
Old Nov 16, 2004 | 02:29 PM
Flava_24/7's Avatar
Boosted Panda
The pieces should be removed from the vehicle to actually be done right.
Old Nov 16, 2004 | 02:35 PM
s0ber's Avatar
How much was it for the intake plenum and the valve covers?
I was planning later on to just snag one at the bone yard and have it done so I dont have to take anything apart until im ready to swap them... I already took the plenum off once.. What a mission
Old Nov 16, 2004 | 07:58 PM
kraimer21's Avatar
1MAX2NV: is that sanded/polished or chromed?
Old Nov 16, 2004 | 10:45 PM
VIP Maxima
lol why u got a cone filter hooked up to the engine instead of the tube??
Old Nov 17, 2004 | 12:56 AM
WOW.... I was looking at the intake manifold I couldnt imagine doing that by hand. it might have to just get a shine with a dremel heh....
and my bad, I was in a rush off to school..I wasnt thinking when I put the head..Close enough :/
That little cone is a breather... My friend jacked one from Autozone and then didnt want it, so i figured what the heII and tossed it on there. Goes with the blue scheme. Has no performance purposes what so ever... actually to tell you the truth, its properly worse cause its closer to the heat of the engine. Unless it gets some cooler air from the back wind of the radiator fans...
Old Nov 17, 2004 | 05:52 AM
sean05's Avatar
do you have any pics of yours painted black? I would like to see that!
If you really want a polished valve cover people sell them on the org. Ive seen them b4. I started on mine and i rubbed most of my finger tips off lol it looks much better then it did with all the oxidation on it but still not mirror shine,
Old Nov 17, 2004 | 07:27 AM
1MAX2NV's Avatar
It's polished.
Old Nov 17, 2004 | 08:07 AM
chenzarino's Avatar
There is no easy way to polish anything. It's a PITA, power tools or not...although tools make a little less of a PITA. I started polishing my motorcycle wheels last winter, and eventually gave up and painted em before my arm fell off. If you have the patience and time, it's worth it tho. Just be aware before you start that its a long and arduous process.
Old Nov 17, 2004 | 08:32 AM
cardana24's Avatar
Blown
I started a similar thread a little while ago...I got started by my self...I have air tools and all the stuff to do it with......to sum it up its not worth your time unless you know exactly how to do it....I realized I was in over my head with about 6 hrs. on it...so I sent it off to a local guy to have it done. I am much happier now...I'll post pics soon
Old Nov 17, 2004 | 09:08 PM
kraimer21's Avatar
It's polished.
would you be kind enough and briefly go through the steps to accomplish something like that?
Old Nov 18, 2004 | 12:01 AM
EZEMaxima's Avatar
I polished my MEVI manifold before installing it on the car. Took me over a month during my freetime to get it to this state. I only concentrated on the top part on the intake runners. I did it by sanding manually by hand and finished it with a air buffing tool.
But I think it goes unnoticed with the rest of the engine polished parts i have in my car. Look, it's hardly noticeable with the FSTB installed.
Eric
Old Nov 18, 2004 | 12:06 AM
MMMMMMM
mevi
Old Nov 21, 2004 | 08:03 PM
2 Da Max's Avatar
dam im trying to sand my down, i used a 100 grit and it seems good so far
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
JonBlz
Oct 5, 2015 06:02 PM
bigfrank
Oct 1, 2015 12:51 PM
