replaced knock sensor but code is still there? why!
Old Nov 19, 2004 | 11:33 AM
Jonny98max's Avatar
i just repalced my knock sensor but when i checked my car for codes, i still have the knock sesnor code....why????
Old Nov 19, 2004 | 11:40 AM
njmodi's Avatar
Do I get a tax break?
Did you clear the ECU codes after replacement?
Old Nov 19, 2004 | 11:42 AM
Jonny98max's Avatar
if i remember right i did.....but if i dint....wouldnt the code automatically go away cuz the computer recognizes that i have a good KS
Old Nov 19, 2004 | 11:43 AM
njmodi's Avatar
The ECU may eventually clear the code - but not immeidately - only after your drive a certain number of miles/etc. Go ahead and clear the codes, make sure its not posted.... drive around and check for the code again.
Old Nov 19, 2004 | 11:46 AM
Jonny98max's Avatar
yea ill clear the codes and hopefully it wont come back.....i know my KS should be good cuz i felt the power back after i replaced it.....
Old Nov 19, 2004 | 01:51 PM
Vaudeville Villain's Avatar
Clear it again and see what's up. Did you replace the harness as well? The faulty part could have been the harness....
Old Nov 19, 2004 | 01:57 PM
Jepht20's Avatar
Custom User Title...
i'd clear it (again), drive around some more, check for codes. if it's still there, then maybe you didn't tighten it within spec or the harness would be faulty. i haven't heard of too many people that needed a new harness though, people mention it, but i've never seen one person who has actually needed it.
Old Nov 19, 2004 | 03:53 PM
NetFurie's Avatar
If you didn't already, also try sanding the grounding points; knock sensors like clean connections.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
