Pulled somes codes **sigh**
Old Nov 21, 2004 | 10:58 AM
Maxine's Avatar
0608-Cylinder 1 misfire
0401-intake air temp sensor
0503-upstream o2 sensor
Where do i start, this just happen has i was driving to get my lowering springs and stillen kit install, so i pulled over just the codes and reset the ecu the codes cel hasn't come back on just but still drives like ****.
So what do i do
Old Nov 21, 2004 | 11:09 AM
maximaseefu's Avatar
Maxine
Check your ignition coil on cylinder 1. it may be bad and that would cause your car to misfire and run like ****. make sure your intake temp sensor is plugged in tight, I had that code and i just unplugged it and plugged it back in and reset the ecu and it went away.
Old Nov 21, 2004 | 11:11 AM
Maxine's Avatar
So just swap out cyl 1 and 3 to see if the code moves
Old Nov 21, 2004 | 11:15 AM
you can do that or it has been suggested the procedure is checking for continuity with an ohm meter. I just posted a question about the procedure myself. I am getting the code for ignition signal circuit so it doesn't even tell me which cylinder.
Old Nov 21, 2004 | 11:16 AM
btw, if you need a coil I have a few for sale.
Old Nov 21, 2004 | 01:34 PM
Maxine's Avatar
Anybody else????
Old Nov 21, 2004 | 10:35 PM
Maxine's Avatar
Old Nov 22, 2004 | 04:58 AM
lilaclucymaxima's Avatar
Team Ramrod
i have had my share of problems in these past couple of weeks... ive had codes come up for
-knock sensor
-engine coolant temperature sensor
-crankshaft position sensor
...i have fixed the engine coolant temperature sensor, i bought a new one at the dealer which was surprisingly cheap... they also told me not to worry about the knock sensor, many maximas they said have faulty codes that give out 0304, which is the code for the knock sensor or circuit fault. i have yet to fix the crankshaft position sensor though
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
