Upgrading wiring harness/headlights
Old Apr 17, 2001 | 10:32 PM
dch95's Avatar
Could someone shed some light as to what is involved in these upgraded wire harness? I picture replacing the harness from the bulb to wherever it leads to which looks like you need to tear into an existing wire harness. Am I wrong or just stupified?
Also what choices are available (in terms of wattage bulbs) in upgraded bulbs and what type of price are we talking?
TYIA for any input on this subject.
Old Apr 17, 2001 | 10:54 PM
Llfe's Avatar
it's pretty simple...there is a relay...2 wires goto positive battery, the upgraded wires then go from the relay and it includes the sockets so that u only plug one of the stock sockets into part of the new harness and the other stock relay u just tie off...it's really easy...u just plug it in...no cutting
Old Apr 18, 2001 | 08:15 PM
dch95's Avatar
So basically....
your existing harness is not removed but you add on a new one. Is that how it works? Also, about how much do they cost and what type bulbs could I go with?
Old Apr 18, 2001 | 10:41 PM
Llfe's Avatar
yea...that's pretty much how it works...u just add it on...well price depends on where u get it from...i got mine for $40 but they're usually around $50...and the bulbs u can use is 9004 bulbs...but now u can use the 100/80 watt bulbs
Old Apr 19, 2001 | 02:48 AM
BluethingSE's Avatar
dch95, I got my upgrade harness from www.suvlights.com
It was only $35 shipped. No more melted sockets now =)
Old Apr 19, 2001 | 07:51 AM
NISMO808's Avatar
Does the harness also have an attachment for the cornering lights next to the headlights as well? I'm running higher wattage polarg dual filament bulbs in there now.
Old Apr 19, 2001 | 07:59 AM
aznbluboy's Avatar
Yeah?... what about the cornering lights... is there anything we could do to that to avoid meltdowns...??? Shed some light on us all you OG's...
Old Apr 19, 2001 | 08:10 AM
bdogg88's Avatar
what does this mod do to your headlights??? i heard of all the ones for your blinker/side marker.. but not headlights.. shed some light on the subject please
Old Apr 19, 2001 | 10:46 AM
Eric L.'s Avatar
The upgraded wiring harness allows you to run 80/100W 9004 bulbs without the risk of melting the stock wiring harnesses. Stock bulbs are 45/65W. Sounds like a good idea, but I would be curious to know whether this would put a strain on the alternator.
Old Apr 19, 2001 | 01:22 PM
Llfe's Avatar
the harness is only for the head lights...there are none for the corner lights ( next to headlights )...i don't think that they would burn
Old Apr 20, 2001 | 07:54 PM
dch95's Avatar
Thank you everybody
BTW, do you all get "flashed" from other drivers with the higher wattaged bulbs or can you pretty much aim them so they won,t interfere with other drivers?
Old Apr 20, 2001 | 09:01 PM
Llfe's Avatar
well...using the 100/80 apc super whites...isn't really that bright...it's somewhat lighter but not super bright...if u were running other 100/80 such as piaas...then those are super bright...cause those are pure white...the ones i have apc super whites...are blue
Old Apr 20, 2001 | 09:22 PM
theblue's Avatar
nice price... I just ordered one from them.. how long did it take you to get your one after ordering?
Old Apr 21, 2001 | 03:32 AM
theblue, I got the harness and some new h-3's in 3 days. I'm happy with the harness...thought those h-3's would be more yellow though, maybe I'll just paint my driving lights yellow like DaveB did.....hmmmmm
Old Apr 21, 2001 | 07:48 AM
Daniel B. Martin's Avatar
This is worth reading... http://lighting.mbz.org/tech/how_to/relays/
Old Apr 21, 2001 | 03:45 PM
dch95's Avatar
Thanks Dan.......
I will look into it and see what I can do considering I did the "Dan B Max" low/high beam mod (which still works great!). I still want them to stay on together.
Old Apr 22, 2001 | 05:38 PM
EWASUP's Avatar
I put in my harness today from suvlights.com. Works great. Also install, my lights I got off ebay. I have since read bad things about lights made in Korea, but I guess you learn as you go.
Paul
Old Apr 22, 2001 | 10:46 PM
Gary95's Avatar
Paul
I bought a pair of Xenon Super White 9004's off an eBay vendor, the brand is Bio Light. Korean. The guy assured me that these are safe for straight replacement of stock bulbs. The rating on this buyer was great... no reports of any problems. I've been running these bulbs on my electrical system for a week now, several hours of night time driving. I checked the wires and they don't look like they've been overheating... The bulbs do seem to be of very good quality. The illumination is nicely bright with a trace of blue--very Mercedes like. Good foul weather performance too, although I'm leaving my driving lights alone (nice to have a variety of lighting types).
Are there any particular warning signs you can spot to determine of your wiring harness is being overtaxed? (beyond the obvious of dripping melted insulation).
~Gary
Old Apr 23, 2001 | 04:48 AM
Originally posted by Gary95
... Are there any particular warning signs you can spot to determine of your wiring harness is being overtaxed?
A blown fuse or fusible link.
Old Apr 23, 2001 | 07:47 AM
dch95's Avatar
Signs.......
~Gary
After your lights have been on for a while, touch the wires to see/feel if they appear hotter than normal or than should be.
Old Apr 23, 2001 | 06:52 PM
EWASUP's Avatar
[QUOTE]Originally posted by Gary95
[B]
Gary
These are the ones I bought and I still put in the harness. Took about 5 minutes and that was only because the directions were clearly written by an asian guy. It said hook the black wire to the Earth (instead of ground).
Loooks sweet though
Paul
Old Apr 23, 2001 | 08:11 PM
Matrix's Avatar
[QUOTE]Originally posted by EWASUP
[B]
Gary
Loooks sweet though
Paul
well Earth = ground. My dad calls the ground of a circuit the 'earth'. But he was educated under the british/asian school system, so they use words like that.
Old Apr 24, 2001 | 07:22 AM
Gary95's Avatar
using a wiring harness anyway
[B]
Gary
Loooks sweet though
Paul
Hi Paul - thanks for the tip. I did test the wires with the brights on and they don't feel particularly hot... But maybe I'll get a harness afterall. Sounds like good insurance. Where did you get yours and how much $$?
Btw, don't these Bio Lights look great? It's just the right whitish-blue color I was looking for. Looks expensive. And they still light up the road nicely in bad weather. I'm thinking of keeping the stock H3 lights in my fogs, though. They seem to still work very well in tandem with the low beams. Why muck with what does the job, right?
Fbana41
Aug 29, 2016 12:18 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
