Full alarm wiring diagram!!!!
Old Nov 22, 2004 | 01:03 PM
Maximasevspec's Avatar
1999 Nissan Maxima Security Information
Constant 12V+ White/Red or White/Purple Ignition Switch Harness
Starter Black/Yellow or Black/White Ignition Switch Harness
Ignition Black/White or Black/Red Ignition Switch Harness
Ignition 2 Starter 2 Wire Red/Yellow or Red Ignition Switch Harness
Accessory Blue or White/Blue Ignition Switch Harness
Tach White/Green ECM, Front of Center Console
Neutral Safety Wire Green/Orange Switch on Driver's Side
Brake Switch Red/Green Brake Switch
Trunk Release Purple/Yellow (-) Driver's Kick Panel
Trunk Pin Purple/Yellow (-) Driver's Kick or BCM below Radio
Parking Lights Red/Green (+) Steering Column Harness
Head Lamp Blue/Black R And Gray/Yellow L at Steering Column
Hood Pin Yellow/Black (-) BCM below Radio
Factory Disarm Green/Yellow (-) Double Pulse Will Unlock Doors
Door Trigger Red/White (-) Low in Driver's Kick Panel
Door Lock Light Green/Red(-) Driver's Door
Door Unlock Green/Yellow (-) Double Pulse Unlock
Driver's Lock Brown/White In Driver's Door
Driver's Unlock Brown In Driver's Door
Passenger Unlock Brown In Driver's Door
Horn Wire Green/White (-) Steering Column
Windows Up LF=Blue/RedData Link Switch, Must go to each Switch in each Door
Windows Down LF=Blue/Black
Old Nov 22, 2004 | 02:22 PM
Tyrexx's Avatar
www.geocities.com/playermaxima
where did you get that? Is there also ones for the 96-98? and 95?
I like the extra few yours has (headlights, windows)
If you have the other years i'd like to update my page.
Old Nov 22, 2004 | 02:33 PM
They fit all from 1996
Old Nov 22, 2004 | 02:50 PM
Tyrexx's Avatar
the extras I dont have on my site stay the same since 95? You sure?
Cool. Thanks
Old Nov 22, 2004 | 03:21 PM
DemonSpawn's Avatar
Windows Up LF=Blue/Black
My '97 doesn't have a factory windows up... do the 99's? Can't remember what I used on the windows down to make all four windows go down with the remote though.
Good info .. maybe I can recheck my wiring and see if that's there and make it roll 'em up too.
Thanks for posting this!
Old Nov 22, 2004 | 04:26 PM
99 dose not have factory roll up but if you install a aftermarket alarm you can use that wire. or i think you can do it through a relay that when you lock your doors the windows will roll up not sure though. you might need another modual.
Old Nov 22, 2004 | 10:54 PM
aznprid972's Avatar
oHH... 2 questions i would love to see be answered in here
1) how to make all 4 windows go down with the remote
2) how to make them roll back up when pressing lock on the remote (even if you have to buy a 'modual' [can someone explain?] )
Old Nov 23, 2004 | 04:06 AM
Ill get back to you on that because i just ordered a Viper 791VX alarm as soon as i get it im putting it in, with it comes a window modual to roll up windows as soon as i install it ill relpy
Old Nov 23, 2004 | 06:59 AM
aznprid972's Avatar
is there any possibility on adding it to our current stock alarm system or must we get an aftermarket alarm system. it would be great to add on to our stock remote features and show off to other people like i do with our window roll down trick. OEM BABY!!!
Old Nov 23, 2004 | 07:01 AM
ny96max's Avatar
youll need to run two sets of wires into each door of the car to the window switch harness. One should be atleast 16gauge the other 18 guage. Its really not as hard as people think to actually wire them, you just need some experiance as far as the wiring end of it goes. Ive done about 4 4thgens in the past few months for the DEI window mods (530t) and they are definitly a cool feature to add onto your alarm. I myself have these but NOT wire to my viper alarm, i wired them to just act as one touch up and down for all four windows at any switch in the car
Ant
Old Nov 23, 2004 | 07:14 AM
HomerMAC's Avatar
Donating i30 Owner
my borthers max before it got stolen had a feature to roll down thte window with the remote..
how come my i30 98 cant do it is it a feature... ? or is it disabled becuase of my after market alarm..?
Old Nov 23, 2004 | 07:35 AM
chenzarino's Avatar
My alarm keeps tripping my CEL with random codes, how can I make it stop?
Old Nov 23, 2004 | 09:22 AM
DemonSpawn's Avatar
Just follow the wiring diagram posted above and get a multi-meter. I wired mine up without knowing what wires were what, I just used my multi-meter to see what was getting power when the windows went.
After that, I ran a few wires to the back windows and viola!
I think I'm going to see if I have the window up wire or not this weekend and see if I can wire that in when the doors lock Either that, or I can tap a relay into the door lock wire to send power to the windows and roll them down - should be relatively easy.
Old Nov 23, 2004 | 02:59 PM
Bumpin Up^^^^^^^
Old Nov 24, 2004 | 10:05 AM
98blkonblk
Hello everyone
I am new to this site, Please rate my car and lemme know what you think
http://members.cardomain.com/ledmaxi
Old Nov 24, 2004 | 10:45 AM
SPiG's Avatar
SomePsychoGuy
^ random post stealing.....
I used to be able to roll all of my windows down with the stock remote by just holding down the unlock button. My current maxima doesn't have remote entry/alarm or any options but leather but I will install an alarm pretty soon.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
mkaresh
Mar 12, 2018 06:48 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Socalstillen
Sep 26, 2015 12:01 PM
