My floor heat don't work........
Old Nov 22, 2004 | 07:20 PM
NyCzBuBBa's Avatar
Ok my floor heat don't work. When I switch it to floor heat it just blows heat out the vents. When I switch to defrost I hear the compressor comes on but no air goes through the vents by the windshield? Any suggestions to be what is wrong? Checked fuses all are working properly
Old Nov 22, 2004 | 11:45 PM
NyCzBuBBa's Avatar
anyone have suggestions that i can try
Old Nov 23, 2004 | 12:12 AM
eckohb's Avatar
ive got the same damn problem, and it sucks. it never used to be like that, and now no defroster, no floor heat. the rear defrost works. also, the heat that blows out the vents is at like half power of what it used to be. wtf is going on?
Old Nov 23, 2004 | 12:23 AM
NyCzBuBBa's Avatar
How bout u go to the mechanic see if they can fix it and tell me what it is so i can fix it
Old Nov 23, 2004 | 04:14 PM
eckohb's Avatar
lol. no money for that. ill just wear a jacket
Old Nov 23, 2004 | 07:26 PM
NyCzBuBBa's Avatar
See floor heat is important cause in the winter your feet get cold. Especially when it snows. Then when your all steamy u need the defrost to work so i think u should get it fixed.
Old Nov 23, 2004 | 08:58 PM
OneToughMax's Avatar
you have auto climate or manual? i've never encountered that problem before, but you should pull the climate controls and make sure everything behind there is plugged in right. if everything is connected like it should be, the next step would be to try another climate control module (from a junkyard), and if that still doesn't work, you might have to put in a call to your friendly dealer
Old Nov 23, 2004 | 11:41 PM
TsingTsaoNYC's Avatar
See what happens when you try to build your own Maxima??!!!
Old Nov 24, 2004 | 04:34 PM
NyCzBuBBa's Avatar
lol at least I can say i built my maxima myself.
captchaos
Mar 15, 2016 12:18 PM
AT978
Sep 6, 2015 10:31 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
JoshG
Sep 5, 2015 10:10 PM
sdotcarter
Sep 2, 2015 09:53 PM
