OD button, and OverDrive itself is bugging out:
Old Nov 22, 2004 | 08:01 PM
Maxima Mike
Well, today, my OD light decided to just come on, I shifted it out of park, and into neutral, and the light stayed on. Then I put it into drive and it turned off. My OD button hasn't been working since I took my shifter off to see what the problem was. Well the plastic has broken around the shifter. After I put the shifter back together, I put the 2 wires in the right places.
Now my OD doesn't work. Same as today, I was driving around, and my OD light decided to come on at random. I could feel the transmission shift out of OD. Then the light disappeared then the transmission shifted it back into OD.
Ever since I took my shifter apart to see what the problem was, I haven't had any OD display. WTH is going on? What can I do to fix this?
Old Nov 22, 2004 | 09:29 PM
Jepht20's Avatar
Custom User Title...
i'd take it apart and take a look. sounds like you have a loose connection with those wires. i've spliced my wires when changing my shift **** and know what you're talking about, only i didn't have it happen often, only when shifting out of park but it goes right off. check out your connections...
if it's not simply the wires, then i can't help you because then it gets hairy. best of luck, i'm pretty positive that's what it will be since you said it has only happened since you had your shifter off.
Old Nov 22, 2004 | 09:48 PM
tedo007's Avatar
faster than you think
ha did you try hit the shifter couple of time so it turns off?
Old Nov 22, 2004 | 09:51 PM
Maxima Mike
No. I shift it out of park, and keep it at neutral to see what happens. The light stays on, and then when I put it in drive, it goes off. I'll see what I can do with those damn wires.
tarun900
19
Dec 20, 2021 06:57 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
Max139617
Sep 29, 2015 06:44 PM
JoshG
Sep 5, 2015 10:10 PM
