raybestos qs pads
Old Nov 23, 2004 | 01:58 PM
Damion Yee's Avatar
raybestos qs pads
I just put in raybestos qs pad in front, they squeal like crazy, took them off and sanded the disk and pads, out them back in, still squeal a little, but the main problem is that there is a grind sound from the pad/disk area. Sounds like a wear indicator noise, but the pads are new. Don't have a clue what it could be.
Al
Old Nov 23, 2004 | 02:08 PM
A32Matt's Avatar
I had the same problem with grinding and squealing up front when i put QS pads on. Make sure that your rotors are good first off all. And for the squealing, make sure you put anti-squeal grease on all contact points of the pads except for the lining itself, and you just have to drive around for a bit before they stop making noise...at least that's what i did.
Old Nov 23, 2004 | 02:11 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Al
Yes they do that, I have them for rear breaks and they are very annoying. I am going to get rid of them by summer time. I can't stand it.
Old Nov 23, 2004 | 02:51 PM
Damion Yee's Avatar
Thanks guys, I just thought I was having this problem.
Thanks again,
Al
Old Nov 23, 2004 | 02:52 PM
Max Noob's Avatar
??. mine were fine..which shims did you use. factory ones or the raybestos ones?
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
05RLS2
Sep 27, 2015 09:24 PM
bbsitum
Sep 11, 2015 04:55 PM
