Use for blank tab next to the dimmer controls **PICS**
Old Nov 24, 2004 | 01:45 PM
Igobuk's Avatar
I didn't like having a blank tab next to the dimmer controls or anywhere else on the car for that matter. I don't know if it has a purpose in other cars but in mine it was nothing... until now. I put in a second security light with a 5mm bright white LED from the group deal. Now the security light can be seen from the driver and passenger sides. They blink in unison which also looks nice and I moved both lights to the outermost positions to give them the best visibility possible.
Old Nov 24, 2004 | 02:19 PM
Maxima99SE's Avatar
will fly for food
i have a switch for my microvision in my blank slot, would look very stock if I didn't have a bright-*** blue LED in it, but i like it
Old Nov 24, 2004 | 02:34 PM
Conrad283's Avatar
I need a truck
Interesting idea. But it says security two times
Old Nov 24, 2004 | 03:01 PM
XoPtOn's Avatar
thats the traction control system button on my car
Old Nov 24, 2004 | 07:32 PM
Igobuk's Avatar
Yeah, but I don't mind. I like how it looks and it's better than just a blank tab.
Besides, all you see through the tint is the LED's which was the main point, to give it a purpose.
Old Nov 24, 2004 | 09:21 PM
2 Da Max's Avatar
hey igobuk i replaced my stock red led with a blue one, my ques is: is it ok to solder the led on the 2 contacts that hold the LED in the security light tab?
Old Nov 24, 2004 | 09:36 PM
Igobuk's Avatar
The stock LED has a tiny resistor inside of the rubber base it's mounted to. I pulled off the rubber base, resistor and stock LED and soldered on a normal resistor and LED directly onto the terminals left behind.
I also measured and made sure the LED was all the way up against the face so that it's as bright as possible. My replacement LED sits high off of the base compared to the stock one. I did both security lights like this.
Also I didn't have a harness for the second security light, so I soldered wires directly onto those terminals too and then spliced it into the stock security light wiring.
Absolutely no problems.
Old Nov 24, 2004 | 09:54 PM
BlueC's Avatar
wat
I guess us Auto 99s only understand that.
Old Nov 24, 2004 | 10:14 PM
RA030726's Avatar
I'm nutty for Nissans
id like to have the I30 remote gas door switch.
Old Nov 24, 2004 | 11:04 PM
matty's Avatar
I have an LED there that lights up when my MEVI opens
-matt
Old Nov 25, 2004 | 08:18 AM
maximaman10's Avatar
I put my DR mod switch there.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
