1996 Maxima--Check engine light and other problems
Old Nov 24, 2004 | 06:59 PM
dms018's Avatar
1996 Nissan Maxima 139,000 miles
The check engine light came on and occasionaly kills at a stop light and bucks while accelerating. Computer check revealed Cam Position Sensor. Replaced Sensor and shortly after the CEL came on and started acting up again. Cam Sensor was replaced again and still the same problem. Can someone please shed some light on this problem? Thanks.
Old Nov 24, 2004 | 08:09 PM
izzydig's Avatar
Did you check the second time, what the CEL was for?
Also, is your Cam Sensor clean...meaning the harness? Full of oil?
Old Nov 24, 2004 | 08:34 PM
maxs4life's Avatar
beside the cel does the car have any bad symtoms
like hard starting or long cranking
Old Nov 24, 2004 | 09:02 PM
MilesA's Avatar
Best advice I can give is to download the Factory Service Manual PDF files, then run through the diagnostic tree for DTC P0340. The FSM says if you have that code, the sensor is not the only possible cause. This type of sensor tends to be very reliable, BTW.
-check wiring harness for continuity or short circuit
-check engine ground connections
-check sensor for resistance 1440-1760 (Hitachi) or 2090-2550 (Mitsubishi)
-check ECM pin terminals for damage
-check surface of camshaft sprocket for damage
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
