High beams do not work/??
Old Nov 26, 2004 | 06:19 PM
99 SE-L
Hey guys my high beams blew out do not work what needs to be replaced nto familair with this,.....
Old Nov 26, 2004 | 06:26 PM
Conrad283's Avatar
I need a truck
The bulb is probably blown. Buy another bulb and try that and if the high beam works then problem solved. If not then there's a problem somewhere else.
Old Nov 26, 2004 | 06:27 PM
99 SE-L
Hey conrad where are the high beam bulbs located i do not see them...
Old Nov 26, 2004 | 06:32 PM
FormorAccordMan's Avatar
There isn't a second high beam bulb. Our cars use a dual filiment 9004 bulb. pull out the bulb and check the filament.
Old Nov 26, 2004 | 06:37 PM
Terran's Avatar
Would both high beams really blow at the same time though? That seems kinda odd unless something else is wrong. May as well give it a shot though...pretty easy thing to check.
Old Nov 26, 2004 | 06:53 PM
Keyser Skoze's Avatar
There may be a short somewhere. The high beam runs off a different wire so that may be something. Both my brights have blown before so it is possible
Old Nov 26, 2004 | 07:35 PM
tommyali
buy silvania silverstars
Old Nov 26, 2004 | 07:48 PM
Bourne's Avatar
Seems to me like it'd be more of a fuse problem... right? If the bulb works with lowbeams but not highbeams, it doesn't necessarily sound like a bulb problem. Unless of course, I'm missing something.
Old Nov 26, 2004 | 07:55 PM
Terran's Avatar
The highbeam filament could be broken while the lowbeam is still good. I just seems odd to me that both HB filaments would go bad at the same time.
Old Nov 26, 2004 | 07:58 PM
99 SE-L
Thanks for all your help guys ill check everythign out tommrow btw terran like 1 month ago one high beam went out and 2 weeks ago another so your are correct they went out at diffrent times but as of now both do not work
Old Nov 26, 2004 | 08:13 PM
Terran's Avatar
Oh. Almost definitely just need new bulbs then.
Don't ya love the easy fixes?
Old Nov 26, 2004 | 08:15 PM
99 SE-L
YEPP, thanks terran got another ? are there sperate bulbs for high/low beam i
Old Nov 26, 2004 | 08:23 PM
Terran's Avatar
Nope. Same bulb. Just pick a 9004 of your choice.
Old Nov 27, 2004 | 09:20 AM
aznprid972's Avatar
this would be a good time to do the "9004 to 9007 bulb conversion"
Old Nov 27, 2004 | 12:55 PM
Batxel's Avatar
blah
just another note... The high beams and low beams use the same fuse. There is a separate fuse for the each head light though (drivers side/ passenger side).
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
