Location of Keyless Entry Module
Old Nov 28, 2004 | 09:17 PM
Dagger969's Avatar
I just bought a 95 SE and it seems to have just about everything. I dont have the original keys and I was wondering if this car had one of those key fob deals....sooo does anyone know where the keyless entry module would be if this car had it?
Old Nov 28, 2004 | 09:18 PM
chenzarino's Avatar
I have an extra remote for sale if you want it, PM me.
Old Nov 29, 2004 | 10:10 AM
Dagger969's Avatar
Anyone know?
Old Nov 29, 2004 | 10:16 AM
Dagger969's Avatar
EDIT: The car is a 96 if that matters
Old Nov 29, 2004 | 12:20 PM
Black Maxima
In the trunk on the right behind the carpet wall.
Old Nov 29, 2004 | 12:45 PM
Dooley's Avatar
Anyone have the link on how to reprogram one of these?
Old Nov 29, 2004 | 01:51 PM
Maxima lover
To enter the ID code, follow this procedure.
Close and lock all doors.
Insert and remove the key from the ignition more than six times within 10 seconds . (The hazard warning lamp will then flash twice.)
At this time, the original ID codes are eliminated.
ID code entry:
Turn ignition key to "ACC" position.
Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered).
At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
Push lock button on the additional new remote controller once.
This ID code entry enable state and setting mode remain until the driver's door is opened. NOTE:
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
my03maxima
Jul 28, 2024 07:40 AM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
