5 out of 6 plugs smell like gas.....
Nov 29, 2004 | 10:45 AM
I just replaced my plugs ...... found the old ones to be bosch instead of NGK.... last friggin owner I guess . Anyway..... 5 out of the 6 smelled like gas..... but the 6th one had no gas smell at all...... and had a little bit of extra oil on it?
PS...... for anyone whos had that bad knock sensor type hesitation when accelerating (hesitation around 3000-4000rpm) even after youve changed your knock sensor ----------> change your plugs..... and for the love of god..... use NGK!!!
Nov 29, 2004 | 11:19 AM
What's the point of this thread? Are you asking why one doesn't smell like fuel?
This seems pretty normal, you can read around learn how to read spark plugs. A little oil is normal for a high mileage engine, typically 3 out of the the 6 I change have a little bit, not dripping, but a small amount around the base of the threads.
Nov 29, 2004 | 02:54 PM
Get a haynes or chilton manual and compare the plugs to the ones in the pictures then you can say if they are in good or bad condition.
Nov 29, 2004 | 03:26 PM
the point of the post was to see if there was anything wrong with engine/coils/injectors...... anything of that nature.... considering only 5 smelled heavily of gas..... and one did not..... whatsoever!
Nov 29, 2004 | 04:52 PM
how many miles on ur car what condition and do u ever use an injector cleaner?
Nov 29, 2004 | 06:18 PM
142,000 KM
great condition.......
and Motomaster (Canadian generic brand) ...... just starting using it
Nov 29, 2004 | 07:39 PM
i get he is trying to say his gas isnt being burn correctly or soem...
