problem after changing spark plugs...
Old Nov 29, 2004 | 05:00 PM
DavidT's Avatar
well, I have a stutter sometimes at idle (shift selector in Drive).
I was told about the 99 coil pack problems. I do not want to blow $400 unless I HAVE to. I do not know how to test the coil packs.
So I changed the plugs. (car is at 94K on factory plugs)
The plug in the cylinder on the passenger/firewall side was a bit unique from the others. The electrode was a bit white.
Anyways, my wife drove it to work today, she told me it started jerking REAL bad, and the CEL came on. She went to Autozone to pull the codes. The tech. said the pulled code was : "ignition system or misfire".
Afterwards, the car was fine...
Any advice?
Is that one white plug and the CEL pointing to an intermittant fouling coil pack?
Old Nov 29, 2004 | 05:04 PM
99 SE-L
Ye one fo the coils are misfiring. now im chaning my plugs and a coil cracked i heard a crack im in process so cant see if its damaged realy dont wanan blow 80 bux for a new coil. will test drive or start after im done yeah but you deff need to cahnge your coils which ever cylinder is misfiring
Old Nov 29, 2004 | 06:30 PM
wmhashem's Avatar
a similar problem happened to me after doing a tune up, i had some cutting problems and my engine light went on. i went to auto zone and my code called for an o2 sensor. after then my car an fine...
Old Nov 29, 2004 | 07:52 PM
BSwithTF's Avatar
Check all the coil packs where they go over the spark plug. A friend of mine had a problem like this and found one pack with a crack at the bottom of it and it was causing it to ground out when it was trying to fire. May not be it but you might double check.
matts95max
Apr 23, 2025 10:44 AM
mvm062
Nov 30, 2020 09:00 AM
markevans999
Sep 10, 2015 04:29 PM
sdotcarter
Sep 2, 2015 09:53 PM
