Can i disable my factory alarm? It cutoff my Fuel!
Old Dec 1, 2004 | 12:08 PM
99GLEE's Avatar
Well i think i was hit with the factory alarm glitch recall i suppose...when i try to start the car it wont start and the red alarm light led stays on while im trying to start it..so i suppose my alarm cutoff my fuel...is there anyway besides going to the dealer to bypass this? i mean any way! i dont want to shell out the 150+ for them to reset a alarm they should reset for free...
let me know if ya know! thanks!
1999 Nissan Maxima GLE
Old Dec 1, 2004 | 01:07 PM
99GLEE's Avatar
Please dont htink im trying to learn this to jack cars or something..My earlier posts show ive been having problems with this for so long now and well cant really afford to take it to the dealership...though i will be forced to if i cant resolve the problem soon enough...well any help or workarounds would be very appreciated..thanks!
-lee
Old Dec 1, 2004 | 04:16 PM
MaximaSE96's Avatar
Maxima Owner
do we have a fuse????? u could try that if we do
Old Dec 1, 2004 | 04:21 PM
Dubbya's Avatar
VK56 Inside
Get out of the car, close the door, lock with the key, and unlock with the key. This will reset the alarm if it is triggered.
Old Dec 1, 2004 | 04:27 PM
MaximaSE96's Avatar
Maxima Owner
forgot about that one
Old Dec 2, 2004 | 02:08 AM
99GLEE's Avatar
tried that lock with the key and unlocked it...it didnt work =(
Old Dec 2, 2004 | 04:51 AM
99se5spd's Avatar
unhook the battery for 30 mins or more
Old Dec 2, 2004 | 09:38 AM
gto400no1's Avatar
it doesnt disable fuel it disables ur starter
-Tom
Old Dec 2, 2004 | 11:15 AM
19maxima95's Avatar
Open your trunk with the key, that did it for me.
Old Dec 3, 2004 | 01:21 AM
99GLEE's Avatar
it cuts off the fuel as i was told by many other people..the starter kicks in just no fuel going to the engine as far as i can hear and see...
so just open the trunk with the key then start the car?
Old Dec 3, 2004 | 04:31 AM
RockfordMax's Avatar
Back from the dead
theres a fuse in the engine bay designated ANTI-THEFT, its 7.5A if im correct. unfortunately, the car wont run without it( at least mine didnt...) so use this knowledge to do whatever...
Old Dec 5, 2004 | 11:21 PM
99GLEE's Avatar
Rockformax its good to know that. Could you please directly me the fuse in the engine..I cant seem to find it? thanks sir!
Old Dec 1, 2011 | 08:53 AM
STAKBUNDLEZ's Avatar
i lost my car key with my only remote...... i believe i am going through the same issues...... going to try all of this today!
Old Dec 1, 2011 | 09:23 AM
asand1's Avatar
Bumping a thread from 2004 is a good way to get banned. OP is an immobilizer issue. 99 is the only 4th gen with immobilizer, and you have a 97. Post your own thread with a descriptive title and you will recieve more help, in this thread you will only be flamed.
Old Dec 1, 2011 | 09:36 AM
GGENIUS's Avatar
yo stack bundles you back from the dead????? dayumn son find them keys
Old Dec 1, 2011 | 09:48 AM
aackshun's Avatar
Yes, I know this thread is from '04, but if another n00b finds this, they need to be set straight.
Your options at this point are:
1. Use another key
2. SOL - Have another key made
The NATS is only responsible for recognizing your key and activating the fuel pump, your key fob, hood, door lock alarm will still work without it.
To by pass this, read what I wrote above, there are MANY ways to get around it.
Not going to help at all.
Again, not going to help at all.
-Tom
False, it kills the fuel pump, the starter has NOTHING to do with the alarm, the starter circuit is extremely simple and all you need for it to work is a working battery, and a working wire harness and relays. NOTHING ELSE, when I say nothing else, I MEAN IT.
That's not a trick to anything, it's just one of those things you happen to do while the problem is being solved elsewhere.
Sometimes the Nats can misread an old key and immobilize your car, at this point in time just take your key out and re-insert it.
Correct!
A 99 will not, correct
Old Dec 1, 2011 | 10:01 AM
it worked!....well it got the alarm off........ car still wouldn't start but i think it might be that the battery is just dead
Old Dec 5, 2011 | 06:40 PM
o well i have changed the spark plugs...... battery.... and even the sensor that tells the cpu that the hood is closed because the white thing was missing....... still nothing..... car is still sitting.....
what i noticed is the red security light will blink until i try to turn the key in the ignition... then it will shut off.....but soon as i take it out it will blink again......
i would love all the help i can get right now
Old Dec 5, 2011 | 06:52 PM
Shift_A32B's Avatar
I agree with aackshun, its better to set things straight. I was reading through out the whole thread, there was no straight answers.
Old Dec 5, 2011 | 08:09 PM
i am............i just have no clue to tell if its the alarm or not...... there is no sound coming from it........and i don't know how to tell if my fuel pump is trying to work or not
Old Dec 6, 2011 | 07:42 AM
max1008's Avatar
I would think you can put your car into the on position a for a a second or two you can hear your fuel pump, then it stops. That should tell you I would think.
Old Dec 6, 2011 | 08:11 AM
Amerikaner83's Avatar
Correct. Turn the ignition to ON, and make sure you have no stereo blaring or anything, you should hear a whine lasting a second or two. That's the fuel pump working, getting ready for the start.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
