Changing rear brakes - "how to" link broken
Old Dec 1, 2004 | 01:57 PM
maxib2's Avatar
Does anyone have a schematics/pictures and write up of how to change the rear brakes on a 97 Max. The "How To" link is broken. Thanks.
Old Dec 1, 2004 | 02:16 PM
NmexMAX's Avatar
dot dot dot ...
Its not hard at all, self explanatory once you get the wheel off, only difference from the front brakes is that you need a "Brake tool" for the back, you can buy this at autozone/checker etc, it looks like a square with different nubbed patterns on it, can't miss it, it's labeled, "Brake Tool"
Old Dec 1, 2004 | 02:25 PM
MaximaSE96's Avatar
Maxima Owner
what he said
Old Dec 1, 2004 | 02:57 PM
ronin22357's Avatar
you can also use needle nose pliers, but the brake tool is alot better way to go
Old Dec 1, 2004 | 04:29 PM
Dubbya's Avatar
VK56 Inside
This is the long version. Disregard the part about the rotor removal.
Tools needed:
Jack & Jack Stands
Four-way or another way to get lugs off
10mm, 12mm, 17mm sockets and ratchet
rear caliper compressor (AutoZone $10)
wd40
Instructions:
1) Loosen rear wheel lugs with car on the ground.
2) Jack up rear end of the car and place jack stands in appropriate places.
3) Finish taking off rear wheels.
4) Remove the E-brake line from the rear caliper. There is a 10mm bolt on the trailing arm that you will need to remove. Just follow the E-brake line back to the front of the car and you will see it in the rear wheel well area. This will give you some slack in the line to make unhooking the cable a lot easier.
5) Remove the caliper. There are 2 12mm bolts holding the caliper in place. They are sort of tough to break free. After the bolts are out, lift up on the caliper. You may need to use a seesaw motion to get the caliper off. Just be careful with the brake fluid line. Once it’s off place it on the ground.
6) Remove the brake pads. Pay close attention to which on was on the inside and which was on the outside.
7) Remove the torque member. The TQ Member is the final piece holding the rotor on. There are 2 17mm bolts holding the torque member on. These are a son of a b---- to break free. Don’t be afraid to use some force. Once the TQ member is off lay it on the ground.
8) Finally take off your old rotor and put the new one on. Then start reassembling.
9) When you put the caliper back on you will need to compress the piston with the rear caliper compressor. Spray wd40 around the piston boot so it does not bind. While the wd40 is penetrating, loosen the master cylinder reservoir cap but leave it on. This is to decrease backpressure in the brake fluid system. Backpressure can blow a seal. Turn the piston clockwise as far as it will go. Make sure that one of the grooves on the piston will line up with the alignment pin on the back of the inside brake pad. I am not sure if yours will have these, but mine did. Now just slide the caliper in place and put the bolts in.
Notes:
Make sure your parking brake is off.
Work one side at a time. This way you have a control to look at if you get lost on reassemble.
10mm bolts are not strong. They only need be tightened a little bit past snug.
After everything is put back together you need to set the rear brakes. Do this by engaging and releasing the parking brake about 10 times or until it feels normal again.
Total time for some one not familiar 2 to 3 hours.
I take no responsibility if you trash your car or hurt yourself.
Hope this helps.
Dubbya
Old Dec 1, 2004 | 04:57 PM
Chunger's Avatar
My other car is a Hybrid
http://webpages.charter.net/chunger/Rearbrakes.htm
Old Dec 1, 2004 | 08:05 PM
Igobuk's Avatar
Haynes manual is money well spent.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
