97-99 Conversion.....?????
Old Dec 2, 2004 | 01:49 PM
maxtuner96's Avatar
Instead of buying the 97-99 front bumper for my Max, I decided to keep the 96 bumper becuase I like that there is a big gap in the front that would really look good with an intercooler behind it (Once I get the turbo). My question is....would the 97-99 grill fit onto my Max with the 96 bumper and headlights? Also, I need some tail lights...bad...anyone with the OEM tail lights selling for cheap?
Old Dec 2, 2004 | 01:52 PM
NmexMAX's Avatar
dot dot dot ...
The grill will fit, there's a pebble beige that has it, can't remember his name off hand.
Old Dec 2, 2004 | 01:54 PM
maxtuner96's Avatar
Thanks! Would you know if it would fit without modification?
Old Dec 2, 2004 | 02:00 PM
Spectre's Avatar
http://forums.maxima.org/showthread.php?threadid=10646
This post should give you all the answers you need. Next time check the How to's FAQ.
Old Dec 2, 2004 | 04:43 PM
Flava_24/7's Avatar
Boosted Panda
It will work. You will need to trim the outer edges of the grill where it meets the bumper. On the 97-99 grill, the outer posts on the grill go down further then on the 95-96.
No need to swap headlights or bumpers!
If you want, I can post pics of a 97-99 grill next to a 95-96 grill to show the diffrence.
I have one of each in my attic,....... along with a bumper,oem tails, alteezas,oem intake,etc.....
Old Dec 2, 2004 | 06:09 PM
sachmo12345
please do that^^^^^^^^
Old Dec 2, 2004 | 07:18 PM
MDeezy's Avatar
wow you have a lot of parts in your attic.
Old Dec 2, 2004 | 07:29 PM
2 Da Max's Avatar
i hope i dont get flamed but why wouldnt a 96 grill fit on a 97 bumper? its too short?
Old Dec 2, 2004 | 10:02 PM
Flava_24/7's Avatar
Boosted Panda
Heres the pics.....
As you can see, the 97 grill has longer outer edges then the 96.
Old Dec 2, 2004 | 10:03 PM
Flava_24/7's Avatar
Boosted Panda
onemore thing.... You guys are WELCOME!
Old Dec 3, 2004 | 01:07 AM
Oblongshapes's Avatar
Keep the 96, i think its better
Old Dec 3, 2004 | 09:07 AM
maxtuner96's Avatar
So, to make the 97 fit onto a 96, you'd just have to cut off about 1/8" off the bottom of the white bars?
Old Dec 3, 2004 | 10:08 AM
Flava_24/7's Avatar
Boosted Panda
Yup! I would probably do it a little at a time untill it fits just right.
A dremel might be ideal for that type of job. You could use a cutting wheel then use a sanding bit to smooth it out.
t6378tp
Sep 29, 2018 04:27 PM
Calabar
Oct 5, 2015 09:57 PM
0m3nc0w
Sep 11, 2015 05:21 PM
JoshG
Sep 5, 2015 10:10 PM
