p1320 or 0201 code
I think it has something to do with a Coil Pack. I had the same code when I forgot to hook one back up. This is going back in time in my memory so dont hold me to it. Hope it points you in the right direction.
Here is some more info out of the FSM concerning that particular code.
*Ignition coil & power transistor*
The ignition signal from the ECM is sent to and amplified by the
power transistor. The power transistor turns on and off the ignition
coil primary circuit. This on-off operation induces the proper high
voltage in the coil secondary circuit
The ignition signal in the primary circuit is not entered
during engine cranking or running.
*Malfunction Dectected*
(The ignition primary circuit is open or shorted.)
*Check Items*
Harness or Connectors (The ignition primary circuit is open or shorted)
Power transistor unit built into ignition coil
Condenser
Crankshaft position sensor (REF)
Crankshaft position sensor (REF) circuit
*Check Items*
Condenser
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
