need a link on how to change oxygen sensor on 97 GLE
Old Dec 4, 2004 | 11:25 PM
Zaypka's Avatar
can anyone give me a link or tell how to
Old Dec 5, 2004 | 06:41 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
for the front Left one, the harness is located right inbetween the Radiator and Rocker Cover. Unplug that and cut off the tie wraps(should be 2 or 3).
for the front Right one, the harness is located on the back top of the engine somewhere. have a friend under the car and unscrew the plug and give it a tug, use a flashlight from the bottom, to follow the wire to the top to fine the harness. there are a couple of wire ties up there, so remove them as well. for your car 97-99, the o2 sensor is in the b-pipe. unscrew the o2 sensor, and follow it up to the top and there will be a black grommit, carfully remove the grommit, and there will be a white clip underneath the grommit, carefully remove that and pull out the wires slowly untill the harness comes out.
after you replace the o2 sensor reset your computer.
for the
kjlouis
Nov 24, 2018 06:09 AM
homeyclaus
Sep 3, 2015 06:15 PM
doobadoo
Aug 15, 2015 06:43 PM
Flores94
Aug 11, 2015 12:53 PM
RealityCheck
Aug 5, 2015 06:18 AM
