where is EVAP canister located?
Old Dec 5, 2004 | 06:41 AM
dzw's Avatar
dzw
Have the code 0111
Diagnostic Trouble Code 0111 is detected when ...
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
This is a "jackpot" code. It points to so many possible causes as to be almost useless. It may be accompanied by another DTC which is more specific.
I want to check EVAP canister first to see if it is broken, but where is it? What does it look like, is it made of plastic or mental?
Old Dec 6, 2004 | 09:17 AM
Max96GLE's Avatar
Is right behind the driver side back wheel. Is a black box hanging from a couple of bolts. What year is your car? .
my03maxima
Jul 28, 2024 07:40 AM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
