Can coolant leak from the thermostat?
Old Dec 5, 2004 | 06:31 PM
|Bijan|'s Avatar
UCF Lexus
Seems like there a little coolant dripping right above and to the right of my alternator. Is that where it could be leaking from?
Old Dec 6, 2004 | 06:10 AM
|Bijan|'s Avatar
UCF Lexus
Old Dec 6, 2004 | 06:12 AM
mzmtg's Avatar
Minister of Silly Walks
It could be leaking from the thermostat, there is a gasket there that could fail...I guess.
There are also two coolant lines that run right over the alt (those .5" diameter pipes on the front of the engine).
How did the swap go?
Old Dec 6, 2004 | 06:36 AM
laylow1988's Avatar
y yes it can
Old Dec 6, 2004 | 07:16 AM
Cutler's Avatar
Check the seal, if I recall right it's nothing more than a liquid Goop type seal anyway. Permatex to the rescue
Old Dec 6, 2004 | 10:46 AM
|Bijan|'s Avatar
UCF Lexus
a lot better than i thought it would
Old Dec 6, 2004 | 10:50 AM
Stephen Max's Avatar
The weep hole from the water pump is in that location. You probably have a water pump o-ring that has gotten old and hard enough to where it doesn't follow the expansion and contraction of the engine block, and it is leaking coolant.
Old Dec 6, 2004 | 12:02 PM
|Bijan|'s Avatar
UCF Lexus
How serious is it? It doesnt leak but maybe 1/2 a tuna can for the whole day
Old Dec 6, 2004 | 12:46 PM
Keep track of your coolant level. It's not serious until you have to add coolant every day. Eventually you will need to take care of it, but maybe not for a while.
Mine would only leak during startup when the engine was cold. Once the engine warmed up and the clearances got tighter around the o-ring it would stop leaking, so I didn't lose any coolant while driving around.
Old Dec 6, 2004 | 08:02 PM
|Bijan|'s Avatar
UCF Lexus
coo, thanks man
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
foodmanry
Sep 24, 2015 12:02 PM
Hdnseek
Sep 9, 2015 05:55 AM
