470k Resistor
Old Dec 9, 2004 | 03:36 PM
19maxima95's Avatar
470k Resistor
I read the thread about switching out the knock sensor with a 470K resistor. Any chance that anyone has a picture of it? Also where can I buy it? I know nothing about electronics and wanted to see if I could do this modification to my maxima.
Thanks!
Old Dec 9, 2004 | 03:42 PM
NmexMAX's Avatar
dot dot dot ...
Thanks!
Hmm, if this is true, if I was you, I wouldn't attemp it, what's the reason? You will probably cause more damage to the engine when you ould have just replaced the KS. IMO
Old Dec 9, 2004 | 05:43 PM
s0ber's Avatar
Did you just post 2 posts about this?
Old Dec 9, 2004 | 05:58 PM
Akumachan's Avatar
I never narc'd on nobody.
just cause no one answered your first thread is NOT a good reason to start a second one.
Old Dec 9, 2004 | 06:07 PM
maximamike88's Avatar
hey im interested in doing this too what are the advantages and drawbacks?
Old Dec 9, 2004 | 06:33 PM
19maxima95's Avatar
I didn't notice that I posted it twice. My bad. I run premium fuel on my Max and I really don't feel like replacing the knock sensor, if it begins to ping out I'll disconnect it. As for now, I like this idea.
Old Dec 9, 2004 | 09:31 PM
Igobuk's Avatar
I did this last week. It definitely worked, the car pulls much better now with no adverse affects and the ECU shows 0505, no codes.
I use 93 Octane, 94 sometimes and so far no knocking noises. I don't plan on keeping my car like this, it's just until after the holidays and I get squared away again with my financial stuff. It's definitely a good temporary fix as long as your car is well maintained with good fuel, plugs, etc.
Find the knock sensor, follow the harness from the knock sensor to the car's wiring. Unplug at the car's wiring. Now leave this harness that goes to the knock sensor aside and insert a 470K resistor in it's place on the car's wiring side. Secure with electrical tape and done.
$1 fix at Radio Shack until you can pay $85+ isn't bad. Just don't leave it like this as you have no safety in case you get bad gas somewhere. But should you hear some knocking, pull over, pull out the resistor and the car will go back into safe mode.
No worries.
Old Dec 10, 2004 | 05:42 AM
19maxima95's Avatar
Thats awesome! Do you have a picture of what you did? Maybe a diagram? I'm not certain as to where in the harness I plug the resistor in.
Thanks!
Old Dec 10, 2004 | 07:11 AM
95bluse's Avatar
I've had this "mod" for over 5yrs, my car has 242,000 miles and no issues so far. Again, I've always used Sunoco 94 and listened for knock (never had), but each car is different. It's a personal choice, I made the decision because I refused to pay the stealership that kinda money for a damn part that is likely to fail again.
Old Dec 10, 2004 | 07:19 AM
s0ber's Avatar
19maxima95: you plug it into the white/black wire on the harness, I believe the other clear wire is ground.
Old Dec 10, 2004 | 07:26 AM
eng92's Avatar
Originally Posted by 95bluse
I've had this "mod" for over 5yrs, my car has 242,000 miles and no issues so far. Again, I've always used Sunoco 94 and listened for knock (never had), but you each car is different. It's a personal choice, I made the decision because I refused to pay the stealership that kinda money for a damn part that is likely to fail again.
You like myself are up in Canada where higher octane fuels are readily available and the average ambient temperatures are typically much cooler than in the southern states. With these factors and the fairly conservative stock ignition timing, you can probably get away with it.
Some states only have 91 octane fuel and their average ambient temperatures are much higher. Using a resister to replace the knock sensor under these conditions is foolish.
If you have a modified ecu with more aggressive ignition timing, and you use this resistor mod, then you deserve whatever happens.
Old Dec 10, 2004 | 08:10 AM
95bluse's Avatar
True, you have a valid point regarding the hotter southern states/lower octane. I won't dream of using it on a modded ecu, like I said each car (and situation) is different.
Old Dec 10, 2004 | 08:13 AM
19maxima95's Avatar
I run 93 octane regularly here, and every other fillup I drop in an STP octane booster just for the hell of it. Now what I don't understand is how to plug the resistor. I saw the picture that Radio shack has, and it looks like a long cable with a bulge in the middle. do I have to bend it to get the 2 connectors to hook up in the harness?
Old Dec 10, 2004 | 08:17 AM
JoeB
I put a resister in my car when my KS died on me. Made a big improvement over a bad one but when I installed the new knock sensor my car ran even better. Just spring for the money and fix it right. Both you and your car will be much happier. $85 and 15 min of your time it's a pretty minor repair.
Old Dec 10, 2004 | 08:31 AM
Igobuk's Avatar
Yeah, just bend it into kind of like a "U" shape and insert each end of the "U" into the car's side of the wiring harness. There's only two contact points so one in each. Secure with tape and done.
Old Dec 10, 2004 | 11:09 AM
19maxima95's Avatar
Excellent! Thanks man!
Old Dec 10, 2004 | 12:01 PM
Broaner's Avatar
2060lbs and falling...
103 Octane and this resistor = problem free.
Old Dec 10, 2004 | 05:13 PM
FazliS85's Avatar
You can drop a STP octane booster everytime you fill up, which is about $4.99 and will cost you more than $85 a year but you cant buy a knock sensor which is intended for the car. Home made intakes i can understand, but this is asking for it. anyways its ur car
Old Dec 10, 2004 | 05:52 PM
MAXRB8's Avatar
I agree, this is a car! Not a 10 speed, you probably paid a few grand to buy it, why screw around, the new KS sensor will pay for itself in fuel savings in the long run anyway.
Old Dec 10, 2004 | 09:59 PM
Broaner's Avatar
That octane **** does nothing. You need to get real high octane fuel to be sure that your running what you want. Or some toulene...
Old Dec 11, 2004 | 04:37 PM
RichMax's Avatar
Boosted like Snipes tax refund
I really did not feel as though I had a choice. Mine was dead since I acquired my car, so wiring in the resistors made a MAJOR difference (no more stored codes or anything, either!) Taking the car to Nissan originally, I was quoted at least $900 to replace the knock sensor. Why? Because my car is California-emissions spec. I looked at the Haynes manual and realized that because of all the extra (CRAP) er... emissions equipment, I would have to remove the entire upper intake manifold to replace the damned sensor. So only 91-94 goes in the tank while the resistor is hooked up. Weigh these costs, and if you do it, for God's sake don't go cheap on the gas or inattentive on your Max
Old Dec 11, 2004 | 08:53 PM
Scruit's Avatar
U wanna try me young boy?
I've had the resistor 'mod' for a year now. I got the new knock sensor but thought that the install would require the full intake manifold removal... I measured the resistance across a good sensor and bought the closest resistor to it. It stopped the computer using the default safe timing map, and I just listened to the engine to make sure there was no audible knock.
I just installed the new sensor a few minutes ago so no more resistor mod!
Old Dec 12, 2004 | 07:07 AM
fizzbob7's Avatar
sorry for hijacking your thread a bit, but i can't find anything higher than a 100K resistor.......it most certainly has to be 470K to work, right?
i have to do this temporarily because the lack of low end power sometimes is aggravating......i put 112K miles on my 85 merkur without a KS at all....oversensitive....i was running 18psi with a t4 and running 12's with it....a pretty extreme setup.....stays in the 90's all summer too, but never had any detonation......i really think people are TOO paranoid about the whole thing......it's not THE END like people think...a lot of times, you hear, fix and have no more problems.....got rid of it on my h22a accord running 11:1 CR too, no problems......gonna do it on the maxima for a while i guess
seen 3 engines for $300 or less with 90K or less on them......if it came to that....
Old Dec 12, 2004 | 09:30 AM
Broaner's Avatar
Go to Radioshack. They have them there.
Old Dec 12, 2004 | 09:25 PM
fizzbob7's Avatar
not around here....checked 4 stores...nothing higher than 200K and the others only had 100K resistors....gonna try some more tomorrow....ridiculous
Old Dec 12, 2004 | 09:48 PM
Igobuk's Avatar
If you can't find a 470K resistor, you can certainly get two 200K resistors along with a 70K resistor and wire them up in series and that will equal the same 470K resistance you need.
knight_yyz
Nov 1, 2015 01:34 PM
Turbonut
46
Oct 21, 2015 08:28 PM
bryants95max
Oct 2, 2015 12:52 PM
ballerchris510
Sep 23, 2015 08:46 PM
