MEVI Kits
Old Dec 9, 2004 | 07:19 PM
ChrisUlrich's Avatar
MEVI Kits
Where can I buy one? Are they easy to install on your lonesome? I have a 95 Maxima 5 Speed.
Mods are Stillen Intake
Stillen Body Kit
New shocks and springs
Y Pipe, cats, and catback
With a MEVI Kit and ECU... what "should" my car run?
Old Dec 9, 2004 | 08:18 PM
maxima_kid's Avatar
www.courtesyparts.com and www.nismoparts.com
If you have instructions, it shouldnt be too hard but if you were clueless enough to ask, i say seek professionals to have it run properly.
Old Dec 9, 2004 | 09:57 PM
I30tMikeD's Avatar
There is no "kit". You can buy the manifold its self from one of the above links, that is if they can actually get them. Then there are a few other parts you neeed. RPM switch, vacuum canister, vacuum soleniod, vacuum hoses, and new TB and IM gaskets would be a good idea.
Your best bet is to find one for sale in the classifieds section that has eveything you need. Going price is about $450ish for an MEVI with all the needed install parts.
As far as install, it's not technically hard but it can be a big job for someone who does not normally install their own mods. Most difficult thing is getting to the coolant lines in the back of the manifold and the EGR valve. Then getting the thing to actually work correctly is another thing guys have problems with. Looking back it is all so very simple but that was after I had done it a few times.
Old Dec 10, 2004 | 06:44 AM
clueless enough to ask? Thanks a lot ***
How much of a difference would I notice with the car after the MEVI/ECU install?
Old Dec 10, 2004 | 06:52 AM
I30tMikeD's Avatar
http://forums.maxima.org/showthread....light=mevi+FAQ
Old Dec 10, 2004 | 09:03 AM
soybeanz's Avatar
I'm thinking about selling a mevi with install parts plus cover too. The cover makes the engine area much cleaner. I bought it used with plans of installing but now I have a wedding date and probably need the $$$ instead. With a mevi/ecu and your current mods, its very possible to have low 14's in the 1/4 mile run.
Old Dec 10, 2004 | 09:12 AM
Jason R's Avatar
aka UNCDooD
and maybe even some high 13's. I already run low 14's w/ stock rev limiter and TS ECU.
EDIT: I meant Technosquare ECU.
Old Dec 10, 2004 | 10:10 AM
Rowan's Avatar
soybeanz, check your pm.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
