indiglo gauges
Old Dec 12, 2004 | 10:19 AM
SDB318's Avatar
indiglo gauges
need some help asap
just removed my gauges and bought them inside. do i just lay the indiglo gauges over the stock ones and srcew the screw back in. but there is no hole for aftermarket ones. and also how did i hook them up when finished placing them.
thanks
scott
Old Dec 12, 2004 | 10:29 AM
jackiss2888's Avatar
no, they just lay over the stock ones.
you have to run the wires to the power inverter it came with and then those to the headlight on/off switch so they will illuminate when you turn your lights on or you can run them to a seperate switch if your lazy, but it will be ghetto.
if they came with a green/blue switch, youll have to mount that somewhere too.
good luck, i personally dont like them though, its just a preference.
Old Dec 12, 2004 | 10:49 AM
SDB318's Avatar
but do i have to screw the screw throught the indiglo gauges
Old Dec 12, 2004 | 10:52 AM
icedogg's Avatar
All you do is get some 3M double sided tape and tape them over the stock ones. Line the little nubs up and you should be set. Just make sure they are down really good or your needles will skip and not work properly...
g.l
Old Dec 12, 2004 | 11:00 AM
like i said, no you dont need to screw them down, liek icedogg said, only tape is needed. but make sure you dont f*** the needles in anyway. chances are, they are going to skip anyway.
Old Dec 12, 2004 | 11:11 AM
SDB318's Avatar
what will happen if i did screw them back in
Old Dec 12, 2004 | 11:18 AM
icedogg's Avatar
**** dude...don't screw them in...whats the point...just frieken tape them!!!!
You won't screw your needles up unless you REALLY mess up. I did mine like 3 weeks ago...needles skipped the first time I put them in because I forgot to get double sided tape, and once i put the double sided tape in, everything was fine...
There is no need to screw them in...
Old Dec 12, 2004 | 11:25 AM
SDB318's Avatar
alright but where the hell is the + and - hook up at
Old Dec 12, 2004 | 11:27 AM
icedogg's Avatar
Someone said this up there somewhere, but you can hook it up to your light switch so it functions just like the stock. Personally, I had neons already hooked up so I had a positive feed. I just tied into that and made a separate switch for it...
Old Dec 12, 2004 | 11:33 AM
SDB318's Avatar
where is the light switch
Old Dec 12, 2004 | 11:53 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
u take the black wire and attach it to one of the many GROUND (GND) screws on the back of the guage cluster. i took my red screw and spliced it into the dimmer switch instead of the headlights. works just fine amd comes on with everything else.
Old Dec 12, 2004 | 11:54 AM
SDB318's Avatar
is the power supply a box or is it on the back of the gauge cluster
Old Dec 12, 2004 | 12:17 PM
omg, the power goes to either the light switch of like 96stillen said, the dimmer, which is byfar way easier. the ground is grounded on the back of the cluster. not hard.
maybe you shouldnt be doing this mod...
Old Dec 12, 2004 | 01:20 PM
Luigi38's Avatar
Hey jackis2888, this is a forum to transfer our knowledge to other ppl such as noobs, you don't have to be harsh on them. Everyone has been at that point where you don't know what you are doing, so how about you help them instead of turn them away from modding thier cars.
-Anyway back to your gauges, if you want you can make small holes with a sharp knife in the gauges to screw them back( I did it and no problem so far 6 months) just be carefull is kind of hard to see where to make the holes.
-Power comes from the dimmer, there are gonna be 3 cables on the dimmer, the black cable is ground, then there are 2 other cables with 5v each. The gauges will work no matter which cable you use. If it is the wrong one the dimmer on your gauges is gonna be backwards(dimmer on high is gonna be low on gauges, dimmer low is gonna be high on gauges)
Hope this helps and keep modding your car man.
Old Dec 13, 2004 | 01:02 PM
SDB318's Avatar
so i finished putting them on and i connected the + wire to the light dimmer and i have this stupid no/off botton. i hate it b/c when i turn on the headlights the gauges dont come on unless i press the botton. is there any way they can just come on when i turn on my lights
Old Dec 13, 2004 | 01:07 PM
Luigi38's Avatar
put the + and - to the dimmer
Old Dec 13, 2004 | 01:11 PM
SDB318's Avatar
i have the - to the back of the cluster on a ground
Old Dec 13, 2004 | 03:23 PM
didnt mean to be "harsh". but i mean, cmon, it was said like, 4 times. not to mention, there are write ups/
Old Dec 13, 2004 | 07:27 PM
SDB318's Avatar
its alright man. but is there a way that i can get rid of that on/off switch that came with the gauges
Old Dec 13, 2004 | 10:35 PM
l3ftonm3's Avatar
I have the same switch and mine come on when I turn the lights on, I dont have to hit the switch, so I dont know whats up. I wouldnt ground it to the back of the gauge cluster though, I have had past problems with that and they stopped working so I needed to move the ground somewhere else.
Old Dec 13, 2004 | 11:47 PM
Luigi38's Avatar
SDB318, dood just hide the little box in the steering column somewhere and have it on all the time. The gauges will light up when u turn your lights on, bc the dimmer only gives power when the lights are on, so do as I tell u, put the + and the - in the dimmer, - with the middle cable in the dimmer(should be black)
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
