Check Engine Light
Old Apr 20, 2001 | 03:30 PM
96vtmax's Avatar
i've got a 96 maxima, and the check engine is now on... local garage said it is from an error code having something to do with loose or faulty gas cap or a bad charcol canister.... We have reset the engine light about 4 times and replaced the gas cap, however the light still comes on.. is this a common problem?? Also, I hit 110 the other day and engine reved down, is there a governor at that speed or something?? seems to run fine after...
96vtmax
Old Apr 20, 2001 | 05:47 PM
gakary54's Avatar
96vtmax
What model do you have? If its a GXE, don't worry it's the governor. I'm afraid I can't help with the CHECK ENGINE light. Mine's dosen't seem to be working right now.
Old Apr 21, 2001 | 05:54 AM
96vtmax's Avatar
It is the GXE, any way to change that(governor)??
Old Apr 21, 2001 | 06:35 AM
Sonic's Avatar
The 'Check Engine Light indicates a problem with your engine or emmisions system, from something as 'small as a loose gas cap' to a cylinder misfire to a bad oxygen sensor.
To check the MIL(Check Engine light yourself): goto vbxmaxima.8m.com/ecu.html , get the 'code' that comes out and interpret it here vbxmaxima.8m.com/ecudecoder.html. From there you can get a general idea of what may be wrong with your engine. As for the governor, the GXEs without the C&C package seem to have the 110 to 120 MPH limiter, the SEs and GLEs seem not to have them. The ONLY thing that you could do to get rid of it is to replace the ECU with another one from an SE, making sure to match transmission and emissions specifications. BTW, why would you want to go over 110?
Old Apr 21, 2001 | 02:41 PM
phatku
96vtmax
i had my check engine light come on so i took it in and nissan changed one of the oxygen sensors. since then the light hasnt come back on. ihave a 96 too.
Old Apr 21, 2001 | 05:02 PM
paco's Avatar
i have a 96 to and this happen 2 me also....i brought it in 2 nissan and i was the oxogen sensors....theres a open recall on the car and if u bring it 2 nissan they will fix it 4 free...later!!
Old Apr 23, 2001 | 09:18 AM
NISMO808's Avatar
The vbxmaxima website doesn't seem to be working.
Old Apr 23, 2001 | 09:22 AM
Daniel B. Martin's Avatar
Seems okay right now...
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
