Addco RSB & rear jack point question
Old Apr 21, 2001 | 05:49 AM
ItchyRichy's Avatar
For those of you with the Addco RSB, where do you jack the rear of the car up from? I've been looking at the Addco bar for almost a year now, but I don't want to lose the ability to use the rear beam as a jack point (if possible).
Thanks!
Old Apr 21, 2001 | 05:58 AM
MarkP's Avatar
Here's the answer....
A couple of years ago on the board someone suggested placing a spacer between the Addco bar and the U-beam axle in the mid point of the axle. I don't remember who now. I use a piece of aluminum plate about 3/8" thick by 6" square that I got from work. Slipping it in place between the RSB and the axle allows the jack pad to lift the car by the Addco bar. I use a block of 2x4 to pad the RSB from the jack. Be careful if you try to use plywood for the spacer since it may likely break.
-Mark
Devo
18
Mar 7, 2016 07:36 PM
Huttig2009
Sep 25, 2015 03:31 PM
JoshG
21
Sep 4, 2015 09:04 PM
JMag90
Aug 25, 2015 09:17 AM
