seats are squeaking.. any fixes known?
Old Dec 20, 2004 | 01:03 AM
kbmaxima's Avatar
i have a gle with tan leather. i dont know why but it really gets to me, just getting into my car and starting her up and hearing the springs in the seat just make that noise. is there any way i can get up in there and stuff it with something? anyone else have the same problem?
Old Dec 20, 2004 | 01:10 AM
Bonka's Avatar
Schnell kaputt
I have the same problem. Passenger seat. I usually drive alone so the noise is there. Goes away when someone sits on it. A lazy fix for me was to recline the seat slightly back and the squeaks are gone. I haven't been able to trace the noise, however.
Old Dec 20, 2004 | 06:52 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
take seats apart, and grease it up, or loose some weight. i think the 1st option is a lot easier
Old Dec 20, 2004 | 06:56 AM
JaMdMax97's Avatar
squirt some KY jelly on it...
Old Dec 20, 2004 | 10:31 PM
cam_honestiam's Avatar
Same problem for me...No fix as of yet.
Old Dec 21, 2004 | 06:50 AM
Max96GLE's Avatar
Re-grease it. I'm hearing winter squeaks on my spring.
Old Dec 21, 2004 | 08:11 AM
kbmaxima's Avatar
where would i start to regrease? no idea where to start.
Old Dec 21, 2004 | 08:19 AM
slfalco's Avatar
I have a 99 with leather, I found that while driving, there was an annoying squeak from the passenger seat (when empty) - turns out to be the bottom of the seat back rubbing against the seat bottom (in that crevice between the seat back and bottom) - I stopped it by sticking a small piece of foam in the gap. The gap is very small, but I guess there is contact between the seat back and bottom in certain spots, and the normal road vibration while driving causes the seat back to vibrate slightly, making the squeak (leather against leather)...
Old Dec 21, 2004 | 11:38 AM
meanbean's Avatar
Ok, the same thing happened to me recently and I was able to resolve it by doing the following.
1) Remove seat from vehicle.
2) Unscrew bottom cushion from slide bracket frame.
3) Replace all medal ring braces that hold leather/fabric to foam cushion with wire wraps.
4) Remove cover from back of seat spine.
5) Wrap the bottom medal bar on the back of the seat with a thin cloth.
6) Place a thin cloth in between the back springs and foam.
7) Reassemble everything, drive and enjoy the silence.
Old Dec 21, 2004 | 06:51 PM
kbmaxima's Avatar
hmm i tried something and it worked for me. I have lumbar support in my seats. Don't know if its available on all maximas, but I only turned the handle halfway and not all the way and silence! hope this works for you guys too
Fbana41
Aug 29, 2016 12:18 PM
Mochedda
Dec 15, 2015 11:27 AM
Derrick2k2SE
Nov 19, 2015 10:14 PM
blakkheartt12
Sep 17, 2015 08:11 AM
carid
Sep 17, 2015 05:00 AM
