Code 0504- TCM, how to remedy this?
Old Dec 20, 2004 | 07:04 PM
ChuckDaMaxRider's Avatar
Can someone help me out here?
0504
Diagnostic Trouble Code 0504 points to a problem with the Automatic Transmission Communications line. Pulse signals are exchanged between the Engine Control Module and the Transmission Control Module to assure smooth shifting during hard acceleration or deceleration.
This malfunction is detected when the ECM continuously receives an incorrect voltage from the TCM. Possible causes include...
- Harness or connectors (The communications line circuit between the ECM and the TCM is open or shorted.)
- TCM
- Discharged or faulty battery
Old Dec 20, 2004 | 07:10 PM
SHADETREE95's Avatar
I would check your dropping resistor I got the same code and that's what mine was. It's located on the driver side between air box and strut tower. It is $40 from the dealer.
Old Jan 11, 2005 | 05:19 PM
S103100F's Avatar
same problem 0504 is it bad how can i check what can it be?
Old Jan 11, 2005 | 10:54 PM
Is your car shifting real firm. What driveability problems are you having.
Old Jan 12, 2005 | 06:01 AM
knight71's Avatar
Maybe this will help (check trouble diagnostics code P0600)
http://members.dslextreme.com/users/...esm/a32-ec.pdf
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
