about stillen's camber plates
Old Apr 21, 2001 | 10:37 PM
danny's_max's Avatar
I'm shocked, just went to the Stillen website to check how much the camber plates cost, and you know what it says?! $369!!! why is it so much? I remembered reading somewhere in here that it is about $240 or something like that. Any idea to why the price is so much? Does it really cost that much to make something like that? Or its probably just a premium, cause of the name "Stillen". Damn, is there any other company that makes camber plates? I want to get plates because I want to assemble everything together, getting Koni's and GC soon, and would like to make the whole process of installing it like "plug-n-play". Its a pain compressing the springs to remove the top hat. And as for the rears, its alot easier than the fronts.
Old Apr 21, 2001 | 11:12 PM
maxium nrg's Avatar
They'll probably be cheaper if you call them and talk to a sales representative. They can usually cut you a deal. There is another company called Ingalls that makes camber plates and has one for the Maxima. You can get it at www.lightningmotorsports.com for 23 dollars I think. But they are only adjustable 1 degrees, whereas the Stillen is adjustable up to 3 i believe. Some of the members suggested just using some 1/2 inch bolts which would be alot cheaper. Hope this helps...
Old Apr 22, 2001 | 10:28 AM
sinewave's Avatar
Ingalls sells camber bolts, not camber plates. The bolts replace one of the two bolts at the bottom of the strut.
FWIW, my front-end mechanic said he hates the camber plates; he says they are a real PITA to adjust.
Old Apr 22, 2001 | 10:54 AM
chris j vurnis's Avatar
The camber bolts are the way to go -- very low cost ---
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
knight_yyz
Nov 1, 2015 01:34 PM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
