Not starting...ideas?
Old Dec 24, 2004 | 01:39 PM
305/85r16's Avatar
Hi,
After I pulled the starter, replaced the worn out brushes, and reinstalled, the car will not start. It turns over, but now acts like the spark plug firing order is wrong. I checked the plugs, wet but firing. I tried starting fluid and got nothing. Checked to see if I knocked any connectors loose or left anything unhooked, nope.
Anybody experience anything like this before? Need some help. Thanks
Jason
Old Dec 24, 2004 | 02:14 PM
2 Da Max's Avatar
check your vacume lines. so it turns over?hmm sounds like an electrical or could be fuel or spark. i mean did you touch your spark plugs? and was the car starting before you rebuilded the starte?
Old Dec 24, 2004 | 02:28 PM
liqidvenom's Avatar
brotherhood of tq
wat vehicle uses that tire size in your sn
Old Dec 28, 2004 | 01:26 PM
305/85r16's Avatar
The car was starting before I fixed the starter. When I tried to start it afterwards it cranked and cranked and acted like it wanted to catch a few times, but now it doesn't even try...like no spark, but I checked, and am getting spark. Like I said earlier, it is turning over like an engine with the spark plug wires in the wrong order. Pulled the front spark plugs and they're wet so it's getting fuel. I'm just guessing but could the camshaft position sensor have gotten fried by jumpstarting?
"wat vehicle uses that tire size in your sn"
My '94 Ford F250 Turbo Diesel 4X4 does. 36" Coyotes.
Old Dec 28, 2004 | 01:33 PM
njmaxseltd's Avatar
Check both crank position sensors and the camshaft position sensor.
They control ignition and fuel delivery. Camshaft position control fuel timing. The initial start actually makes all the injectors spary at once, you've got wet plugs so fuel is working. Your spark isn't right so check the crank position sensors first.
Old Dec 28, 2004 | 01:42 PM
305/85r16's Avatar
I can't get anywhere using the search. Can you tell me a little bit about the crank position sensor? How do I check if it, and where do I access it from? Thanks
Old Dec 28, 2004 | 01:44 PM
Ant96GLE's Avatar
^^^ What I was gonna say
