long-travel rear shock mounts
Old Dec 24, 2004 | 07:23 PM
hollaatchaboi's Avatar
Those who have purchased this...does it really help (does that extra inch make a difference?). I'm going to drop my car using B+G springs and AGX's. Do i need to purchase these and is there anything like this for the front?
Old Dec 24, 2004 | 07:53 PM
mansurxk's Avatar
i havnet put mine on yet, but the front struts need to rotate, so no thers nothign liek that for the front.
Old Dec 24, 2004 | 08:02 PM
Ant96GLE's Avatar
They're definately worth it, considering you'll be hitting bumpstop out back more than in the front.
Old Dec 25, 2004 | 06:28 AM
RA030726's Avatar
I'm nutty for Nissans
i have them and yes they work
Old Dec 25, 2004 | 08:34 AM
juani's Avatar
Rockin' VK56!!
hmmm how wierd. I always hit front right bump stop but never hit any other bump stops...
Old Dec 25, 2004 | 09:29 AM
njmaxseltd's Avatar
B&G springs have a pretty good drop. Those mounts give back suspension travel and puts the rear shock in a more neutral position. The end result is that the suspension will be able to soak up road irregularities while maintaining ride comfort and control.
Also make sure you either cut off at least 1-1/2 rings from the stock front strut bump stops or use the KYB boots with that setup.
Old Dec 25, 2004 | 09:51 AM
OK...what will that do?
Old Dec 25, 2004 | 10:10 AM
njmaxseltd's Avatar
That gives the front struts a bit more room to travel.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
ef9
Sep 5, 2015 11:18 PM
