Climate control noise..
Old Dec 25, 2004 | 08:19 PM
eclypsecl's Avatar
Turn on climate control..and then I can hear a fluttering..like a ticking as if something is touching the fan..the odd thing is that when I increase the speed of fan..the noise goes away..but so damn annoying..any quick fixes? I don't even know where the fan is..
Old Dec 25, 2004 | 09:16 PM
talisman311's Avatar
There's a TSB on this. read the stickies, i know it's in there somewhere.. something about the fan shroud hitting.
Old Dec 25, 2004 | 09:18 PM
nitromax's Avatar
it's under the right side of the dash, and probably has some trash /leaf down in it. 2 or 3 screws should get you in there, so you can clean it. pita the 1st time you do it.
Old Dec 26, 2004 | 06:21 AM
eclypsecl's Avatar
yah I didn't find it in the stickies the first time around I'll look again, nitro right side of dash..passenger side I'm assuming?
Old Dec 26, 2004 | 09:27 AM
99se5spd's Avatar
same thing here mostly on speed 2 (acc) pulled it down, didnt notice anything but some dust so started cleaning it off and noticed a couple of broken blades...not missing, just cracked. ordered new fan will be in in a couple of days...40$. oh and a tip, theres a 10mm bolt on the dash down near the passenger kick panel, take that out so you can pull the dash away a bit to drop the motor.
Old Dec 26, 2004 | 03:26 PM
eclypsecl's Avatar
thanks, where'd you order the fan
Old Dec 27, 2004 | 10:58 AM
Raw_Toast's Avatar
I have this same problem, and yesterday tried dropping the blower out of the car to get a look at it, I couldnt get the fan assemble to drop past the cross member that holds the bottom of the glove box to the dash. I did remove the nut mentioned above, but could not get the dash to pull forward enough to have the fan drop down. Is there a trick or secret to this? I also am interested in getting a new fan assembly, especially if it only 4o bucks, I was expecting quite a bit more, where do you find that from, was it online or just a shop?
Old Dec 27, 2004 | 03:43 PM
99se5spd's Avatar
the fan was ordered from southern states nissan in raleigh nc. i think its like 42$ or so, the whole fan assembly(fan and motor) runs about 170$.
raw toast:the cross member only has 2 (3?) phillips screws holding it in, than with that 10mm bolt out you can pull that section of the dash away and the fan will come right out.
fan should be in wednesday, ill post back and let you guys know if that fixes the "tick"
Old Dec 29, 2004 | 01:51 PM
keehoon's Avatar
which one is fan?
white one?
Old Dec 29, 2004 | 04:06 PM
eclypsecl's Avatar
did you remove the glove box to do that?
Old Dec 29, 2004 | 04:11 PM
eclypsecl's Avatar
yah the white thing looks like it's the fan thing...haha try turning on climate control...see what happens. if it whirs there..it's the one
Old Dec 29, 2004 | 04:18 PM
jackiss2888's Avatar
hehe "pita"
Old Dec 30, 2004 | 01:08 PM
nitromax's Avatar
the blower motor is actually the black part w/the hose going to the side of it. unbolt that and the fan wheel is attached. check the tips above to ease the pain!
Old Dec 30, 2004 | 04:52 PM
eclypsecl's Avatar
maybe this should be stickied?
Old Dec 31, 2004 | 06:30 AM
keehoon's Avatar
thanks nitromax!!!!!!!!
Old Dec 31, 2004 | 06:44 AM
99se5spd's Avatar
okay, so i replaced the fan and blew out the motor with air...no change, still ticks the same. maybe you guys will be lucky and just have a leaf down there or something.
Old Dec 31, 2004 | 08:18 AM
nitromax's Avatar
While The Motor Was Out Did You Look Up Into Heater Box/fan Hole To See If Anything Was Sticking In There? Some Times The Smallest Thing Out Of Place Can Be The Culprit.
Old Dec 31, 2004 | 08:48 AM
WaarrEagle's Avatar
See if this helps you get everything apart - I have never done this but will probably do it before summer.
http://forums.maxima.org/showthread.php?t=313853
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
