LED shift knob mod?
Old Dec 25, 2004 | 09:37 PM
joew's Avatar
LED shift **** mod?
I’m interested on modifying my automatic shift **** with LED manual shift **** if that is possible. I wouldn’t mind drilling some holes on the aftermarket shift **** if that is possible as well. Have anyone done this?
Old Dec 25, 2004 | 10:53 PM
dawalkster's Avatar
is craving Bojangles
i highly doubt that you could use a manual shift **** on an auto tranny. i mean what would you do with that button?? if you want a knew auto shift **** i think levoc makes a good one but i dont think its gonna have any leds in it. for that youll hafta make a trip down a certain aisle in your grocery store..
Old Dec 26, 2004 | 11:26 AM
TJ_Max's Avatar
Paradox Systems Vendor
well to be honest, u can do it....i use levoc auto shofter wit OD button:
but only way i see to use manual shifter is: when u pull off the stock shifter, u need to take tthe two od wires and hook them up to a switch....so ure OD button is mounted.....now u have that piece that autos use to "unlock" shifter so u can shift from park to drive,for example. all this piece is is a rod inside the shift rod, if u can have that pressed down and then push ure Manual Shift **** onto the shifter rod with that inner rod pressed down....ure in the money....now u have amanual shifter and u dont need that side button n e more, u can just row through all the gears, (although i think this is dangerous) u can accidentally throw the car in reverse or park while ure driving with this setup....this would be interesting though...if u can put a shift boot over it, u will look like a 5spd and u can row through ure gears....
Old Dec 26, 2004 | 07:24 PM
joew's Avatar
sound dangerous enough, i guess i'll back out of this one.
Old Dec 26, 2004 | 09:04 PM
HoLLaAtMyMaXx's Avatar
tj max where did you get your carbon fiber dash kit it looks awesome ......im also located in new york im in staten island ....anyways let me know about that dash again it looks sick
Old Dec 26, 2004 | 09:39 PM
TJ_Max's Avatar
mine i actually bought off of a friend for cheap, it was on a board, in a box in a clear bag.....i know that doesnt help, but there is a spot that does them very well in NYC, ill ask chinox for u, he knows the name of the spot, i forgot it....its like nycdashes or something like that
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
atriuum
Sep 28, 2015 01:19 PM
