When car is in neutral...flywheel or clutch makes a knocking sound
Old Dec 27, 2004 | 02:38 PM
|Bijan|'s Avatar
UCF Lexus
When I crank up my car, it sounds normal...until I release the clutch while it's in neutral. It seems like the clutch or flywheel is knocking something every RPM @ idle. When I put it in gear and go....it goes away.
It's not very loud, but I noticed it today - Any ideas on whats causing it?
Old Dec 27, 2004 | 02:39 PM
Jeff92se's Avatar
I'm needing a caw
Tranny bearings
Old Dec 27, 2004 | 02:44 PM
|Bijan|'s Avatar
UCF Lexus
more info...?
Old Dec 27, 2004 | 02:47 PM
Jeff92se's Avatar
I'm needing a caw
You know the bearings inside the tranny? Probably those.
Seriously. Either the input/outputshaft bearing or if you are lucky, the TO bearing.
Originally Posted by Soul Fly
more info...?
Old Dec 27, 2004 | 03:28 PM
AsthmaMax11's Avatar
aren't you getting sick of these ****ing cars? It's like you fix one thing and another one breaks. did you ever get another clutch?
Old Dec 27, 2004 | 03:30 PM
Blu's Avatar
Blu
the tits
sound like the TO bearing, only reason I know this is bc Matt told me what it was when I heard it on his car.
Old Dec 27, 2004 | 03:45 PM
96 N/A Max's Avatar
i will tell you right now it is deffinately not the TO bearing that is rediculous that some1 would even think that. tell me how a throw out bearing is goint to make noise when its NOT spinning. he said it make a noise off the clutch therefore the to bearing is in a resting position not riding on the pressure plate. any ways it is almost definately 1 of the bearings inside the tranny such as either 1 of the input shaft bearings or output shaft bearings. i know i just finished rebuilding mine today in my garage. thank you very much
Old Dec 27, 2004 | 03:47 PM
Ant96GLE's Avatar
12345
Old Dec 27, 2004 | 06:29 PM
BigLou93SE's Avatar
I don't really know what you said , but the TO bearing will make a whining noise when the clutch pedal is not pressed -- in the outermost position. It goes away when the clutch pedal is depressed, and comes back out when the clutch is let out...
Old Dec 27, 2004 | 06:52 PM
96 N/A Max's Avatar
youre ignorant go away and youre 17
Old Dec 27, 2004 | 07:04 PM
BigLou93SE's Avatar
and your 19...if you're going to try to make an educated reply about something mechanical that most likely will get confusing when many people are talking about it, at least try making the explaination sound a little bit intelligent. Use punctuation, capitalization, and correct spelling so that everyone can make sense of it. What I said was not wrong -- I had a faulty throwout bearing, and I know the noise. However, I never said that YOU were wrong either, it could be many things. Go find yourself an education, as$.
Old Dec 27, 2004 | 07:06 PM
BigLou93SE's Avatar
Oh, by the way, Ant -- that was one of THE funniest threads (red/clears and clear paint) that I've read so far. Poor guy, wasted $4.00. I guess he deserves it.
Old Dec 27, 2004 | 07:09 PM
SR20DEN's Avatar
VQ Wizard
I will tell you that your grammar is definitely terrible. It is ridiculous to think that anyone could possibly understand you. Tell me how you honestly plan to get your point across when you obviously lack the grammatical skills to convey your train of thought.
Old Dec 27, 2004 | 08:55 PM
96 N/A Max's Avatar
sorry about the grammer and punc. but i have rebuilt many five speed trannys and i know what goes wrong with them and the noises they make
Old Dec 27, 2004 | 09:04 PM
|Bijan|'s Avatar
UCF Lexus
Stop with the
I dunno if it's the TO bearing, maybe it fixed itself Cuz its not doing it now....
Old Dec 27, 2004 | 09:14 PM
SR20DEN's Avatar
VQ Wizard
You can't know everything. And don't assume that you're the only one that has.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
follyburr
Aug 7, 2015 09:50 PM
