Rear window switch LED's
Old Jan 5, 2005 | 07:34 AM
hollaatchaboi's Avatar
I was installing led's in my window switches last night. However, last night, when i got to the rear window switches, I couldn't get the led out. After hassaling with it for a long time, it finally came off, but it came of with the contacts. Now all thats left is cardboard and solder won't stay in the spot. Any suggestions of what to do now?
If I have to get new rear window switches, any suggestions on how to take out that led safely?
Old Jan 5, 2005 | 08:01 AM
MAXRB8's Avatar
Were the LED's almost flush with the circuit board for the rears? I bought an extra switch set as a backup incase I screwed up, my Max is a 95 and the rear switches turned out to be different so I'm assuming they are for 97> so I had to use my orginals. The front switched out perfectly, if all else fails I have a rear set that have been converted to ocean blue 5000mcd that I'm assuming will fit 97>? and I have a front set spare that I can convert (have extra ocean blue 5000mcd LEDs) or leave factory . You can try just soldering a wire to make a "bridge" from point to point connection doesn't look as neat but it works. Removing that LED is a B***H, you just have to loosen it from the solder from underneath, don't leave heat on too long and keep pulling on it with pin nose pilers and persuasion good luck
Old Jan 5, 2005 | 09:10 AM
The led's were flush with the circuit board. I did my fronts already, they were easy. But my rears have nothing to solder to. When i finally got the chip off, it came out with the contacts and the solder won't stay on the board. I don't know what to do now.
Old Jan 5, 2005 | 05:21 PM
Igobuk's Avatar
Solder it like this where the longer lead in the picture is the postive lead of the LED.
Hope this helps.
Old Jan 5, 2005 | 09:01 PM
Thanx Igobuk, it worked
Old Jan 6, 2005 | 01:48 PM
Igobuk's Avatar
Nice, glad to help.
AcuraLegend
Oct 17, 2016 08:47 PM
vingodine
45
May 21, 2016 12:46 PM
AcuraLegend
Sep 22, 2015 04:22 PM
MaxLife17
Sep 8, 2015 02:36 PM
mpbclutch33
Aug 21, 2015 06:09 AM
